While the nose cone is off for the AVO kit I thought I would fix the paint issue...incorrect prep caused the paint to peel off. The problem is that while I can find diamond blasting for metal, I cant find anyone who can blast the urethan nose cone.
Anyone got any contacts in PERTH?
Media blasting NA Nose cone
- Mr. Keets
- ak_perth
Re: Media blasting NA Nose cone
I dont know if they do what you want to do, but i can recommend a good panel beater/spray company in Ozbourne Park, Perth if you want to contact them.
The man to ask for is Phil and the company is called AFM, tel: 08 9244 5333.
Tell him Al with the red MX5 recommended him. If he cant do it i'm sure he can recommend someone else.
Good luck
Good luck
Is there anything wrong with sanding with wet/dry paper?
Soda blast, what we use on the plastic panels on the coaches.
- Mr. Keets
Thanks for the replies guys.
Call AFM, mention Al...cool
Wet and dry...I'm relying on a mate to wrangle that part of the build while I'm OS so it's probably a bit much to ask
Soda blasting is what I'm after, cant find it in Perth for some reason
