during heavy down pour with a/c on, water falls on right foot only on right corners from above the foot well..................... i am dumbfounded?
any suggestions??
cheers
wet driver's feet
- aviper4u
wet driver's feet
- Regie
- Vehicle: NC - V8
Re: wet driver's feet
air con drain hose has come off
- aviper4u
Regie wrote:air con drain hose has come off
ah ok... though i thought the a/c hose is on the passenger side? and had the a/c on for over an hour yesterday no probs
i will check under the footwells asap though just thought someone else might have had wet feet when turning a corner, doesnt help if barefoot and already slippery during a downpour
- timk
- aviper4u
saboteur wrote:Maybe you had a moment and wet yourself?
wtf??? wats with forums and bs replies........
- PaulF
aviper4u wrote:saboteur wrote:Maybe you had a moment and wet yourself?
It's something known commonly as "humour".
- dave2221
PaulF wrote:aviper4u wrote:saboteur wrote:Maybe you had a moment and wet yourself?
i dont think its as commom as most people think.
same can be said about common sense... its not so common either.
- aviper4u
dave2221 wrote:PaulF wrote:aviper4u wrote:saboteur wrote:Maybe you had a moment and wet yourself?
fair enough i guess it counts as a bump eh
anyways i will check under carpet and footwells this weekend and see what i can find
- aviper4u
well checked below both footwell's and can confirm the a/c drain is not clogged though as for driver side issue still a mystery???
do other owners on the forum ever notice any rust on the metal steering column cover underneath the dash?
aviper4u wrote:do other owners on the forum ever notice any rust on the metal steering column cover underneath the dash?
Yeah I have a bit of surface rust, not a lot though.
- aviper4u
emily_mxV wrote:aviper4u wrote:do other owners on the forum ever notice any rust on the metal steering column cover underneath the dash?
yea same here just surface rust...... looks like its common.......
thought it might be from a leak
aviper4u wrote:during heavy down pour... water falls on right foot only on right corners from above the foot well...
Not sure if the NB was similarly affected, but I've seen NAs in which, after rain or a wash, water drips down the black plastic panel immeidately to the right of the accelerator pedal. The water subsequently gets under the carpet & soaks the underfelt. Perhaps your right foot is getting wet when it's on the accelerator pedal up against this panel from water that perhaps drips down it.
