DIY door trims
Re: DIY door trims
good work!!
looks really neat
I would do it to my car but im lazy!
looks really neat
- tobias
Re: DIY door trims
Yes, yes it is
I'll find some belts for me to use
- tobias
Re: DIY door trims
mr bender wrote:good work!!
looks really neat
Thanks man it's alot easier then you think, I would do it to my car but im lazy!
If you lived in Melbourne I would help you out i have another 2m of suede left over
Re: DIY door trims
i will have to track down some suede over here and do what you have done.
it will match im steering wheel!
- Bizi
Re: DIY door trims
I've seen DIY threads on doing a suede steering wheel wrap.
If you're interested once you've gotten over this big job!
All in one post. This person said it took 5hrs all up.
Best tip was using tape to wrap your existing wheel, then use that tape as the template. There are other DIY threads out there but I figure this one's great.
http://www.e46fanatics.com/forum/showth ... p?t=570659
I've love to do the wheel, knob & pads (like yours).
Will you get a much better result from stripping and repadding, rather than just glueing/stretching the material over the padding?
Thanks for sharing the DIY!
orangemx5 wrote:mr bender wrote:good work!!
looks really neat
- Cerberus
Re: DIY door trims
Nice one.
Might have to copy this sometime
Did you do the centre console carpet yourself?
Goes well in a minimalist kind of way.
- tobias
Re: DIY door trims
Yeah I did that as well needs to be re-done though, thanks
- CheyneX5
Re: DIY door trims
Spotlight would be a great place to start looking. My GF always goes there for supplies when she is making crafty stuff. They have all the fabrics/vinyls you could ask for...
Leopard print door trims anyone?
90' NA6 - Classic Red
- Cerberus
Re: DIY door trims
You should do a guide for the centre console carpet, that way I dont stuff up when I do it..
- tobias
Re: DIY door trims
Cerberus wrote:You should do a guide for the centre console carpet, that way I dont stuff up when I do it..
This should be all you need for the carpet, just chose your fabric and stitch some velcro around the edge too stick it down, good luck!
- Cerberus
Re: DIY door trims
Ah perfect thank you very much!!
I'll do that tomorrow
Had a go this afternoon at the drivers door trim.
Here is mine:
Imitation is the sincerest form of flattery
Here is mine:
- Bizi
Re: DIY door trims
Nice to see that you incorporated the ghetto GT3 door pull.
orangemx5, I was looking at the Clubroadster carpet console thread again.
http://www.clubroadster.net/vb_forum/sh ... p?p=999138
It just needs a bit of tweaking of the underside, so it's something on my list, too.
Nice classic tweak to complement the door trims.
Re: DIY door trims
thanks so much for the post - spent an hour this weekend being a copy cat and I think it worked out really well, and surprisingly easy and quick to do! now what to do with the extra 2m of material......
- Bizi
Re: DIY door trims
Rasco wrote:thanks so much for the post - spent an hour this weekend being a copy cat and I think it worked out really well, and surprisingly easy and quick to do! now what to do with the extra 2m of material......
Talk to Pamex (see her Garage Thread) and compare your handiwork with her recent Yahoo Japan 'steal' of a Nakamae carpet.
I bet you could, between you, make a coupe more for others here and recoup your costs or improve your console handiwork!
Re: DIY door trims
Happy to! will try and find the thread!
