If the car is still under warranty, take it back to the dealer and get them to fix it AND replace the carpet.
If not, well, someone with more experience on the NC should be able to help you.
NC passenger carpet severe water logging
- Benny
Pop out the rubber bung in the passenger footwell (it will let all the water out at least).
- de Bounce
I'm guessing you have a soft top, if so check the drain holes which are located behind the seat belt top mounts. They could be blocked causing the flooding.
Last time this was discussed, I think someone mentioned a recall affecting the NC's.
There is some info HERE and HERE although the discussion was NA/NB specific, some of the principles apply to the NC.
This one is for the NC HERE
Guys, I've owned my NC for about 2 months now without seeing rain, untill now and yes the passender side carpet is wet
not soaked but a little damp and the car is starting to smell damp.
Without taking it to the dealer is there instructions somewhere on how to flush these drains out as it's about 2 months out of warrenty.
Abit upset about splashing up a sh*t load of money and to have problems already
Not happy.
Paul
Paul
"Life's pretty straight without... Twisties".
Winning Blue 2006 MX-5
the dealer is sure to give you advice on what to do-- go and have a chat unless a forumite has nailed it.
Doing alot of searching and it apears to be a problem with the NC's
Found a Mazda Service Bulletin, looks like a big job.
http://www.finishlineperformance.com/pd ... -2104c.pdf
Users browsing this forum: Bing [Bot] and 3 guests
