Boot relining
Benny
Boot relining
Postby Benny » Wed Sep 23, 2009 1:54 pm
Buy a good set of boot liners off a wreck and put them in the same way you took them out.
If you want to make up a set by hand, good luck!
Boot relining
Postby Mr Morlock » Wed Sep 23, 2009 7:00 pm
the liners are done with a flocking process and as far as I am aware you cannot diy. A motor trimmer might have an idea if you are able to get it re done. As an alternative it may be a proposition to rub them down and perhaps sprayed with a sound deadener. I guess the trims themselves might be vacuum formed which gives the shape to conform to the contours in the boot. As Benny suggested a 2nd set ( new cost??) might be a thought.
Users browsing this forum: Google [Bot] and 1 guest
