ABS Plastic
ABS Plastic
Postby Hammer » Mon Apr 27, 2009 4:35 pm
Try Clark Rubber. They have a store in Fyshwick.
Fyshwick
84 Newcastle Street
Fyshwick, ACT, 2609
Ph: 02 6280 6818
Fax: 02 6239 2514
Fyshwick@clarkrubber.com.au
lightyear
Infinity & Beyond
Vehicle: NA6 - Turbo
ABS Plastic
Postby lightyear » Mon Apr 27, 2009 4:42 pm
I wouldn't use plastic. It will crack when you have an off. Look at the one i just made on my car. It is from an alloy supplier. It is used by signwriters. Very stiff, but u can bend it. It is plastic with alloy laminated to both sides. Comes in 3 and 4 mm.
ABS Plastic
Postby Mr Morlock » Mon Apr 27, 2009 9:26 pm
I do not know Canberra but it is likely there is a plastics supplier for sheet for construction and fabrication. Toolmakers making jigs and the like use plastics which they can cut and form.Some of the industrial suppliers may also carry a limited range of plastic sheet. If you check Plastral Fidene ( Sydney) web site and perhaps ring one of the sales people and ask for a recommendation on which plastic to use and they might be able to give you a lead to someone they supply in your city . Cars use many different plastics all to suit specific requirements. Bumper bars are typically moulded from polypropylene and one of the characteristics of some plastics is that they are flexible but have good impact resistance without cracking. I do not know what product Lightyear is referring to.
philz
Wheel guru
ABS Plastic
Postby philz » Mon Apr 27, 2009 11:10 pm
lightyear wrote:I wouldn't use plastic. It will crack when you have an off. Look at the one i just made on my car. It is from an alloy supplier. It is used by signwriters. Very stiff, but u can bend it. It is plastic with alloy laminated to both sides. Comes in 3 and 4 mm.
ABS plastic is okay to use. it won't crack that easily, but merely bend/flex alot before it can crack.. which is hard. It's the same stuff that car manufacturers use on lips, the worse it can get is really bad scraps and scratches.
kitkat
ABS Plastic
Postby kitkat » Tue Apr 28, 2009 1:40 pm
LMW wrote:Thanks very much for the prompt response guys. It gives me some leads to follow up.
Could you please update this thread with prices when you get them?
Im interested in making a flat underbody in the not to distant future.
ABS Plastic
Postby Mr Morlock » Tue Apr 28, 2009 5:09 pm
Kitkat- Plastral Fidene have an office in Brissy- suggest check out their website.
16bit
Vehicle: NB8A - Supercharged
ABS Plastic
Postby 16bit » Fri May 01, 2009 10:06 pm
speaking from experience is much much harder then it looks. have a look at the big forum. I think one of the sponsors is in the middle of making one for an na. there are oh so many complications when you get down to it and test it.
kitkat
ABS Plastic
Postby kitkat » Fri May 01, 2009 11:00 pm
Im always up for a challenge and im not expecting it to be easy :D
The rough plan is to make an underbody brace with mounting points that the flat underbody can screw into. The design of the front and middle sections (flat underbody) shouldnt be too difficult but designing a rear section thats effective i assume will be.
Now just to find time, money and effort... :roll: :lol:
Thanks for the info LMW. And big forum = http://forum.miata.net/
16bit
ABS Plastic
Postby 16bit » Sat May 02, 2009 8:51 am
no amount of thread lock will work with screws. unless its aluminium on aluminium. it just won't hold in steel.
PUR157
ABS Plastic
Postby PUR157 » Sat May 02, 2009 2:53 pm
A splitter you say? Why don't you use MDF?
Some guys that run a popular TV show over in UK tried it... :mrgreen: :mrgreen: :mrgreen:
Oneness of Man and Machine
