I got a chiped windshield
wun911
Postby wun911 » Wed Feb 20, 2008 8:55 pm
Anyone know where I can replace the typical glass windshield with a thin flimsy acrylic one?
every ounce counts
NMX516
Postby NMX516 » Wed Feb 20, 2008 8:59 pm
Nope, because it's illegal for road use. I doubt very much whether anyone would make such a thing for the 5 at all....
Steampunk
Postby Steampunk » Wed Feb 20, 2008 9:04 pm
X2
car glass is meant to shatter into thousands of tiny, blunt little pieces.
Acrylic/plastic etc will turn into a few pointy daggers.
Call Windscreens O'brien et al asap.
AB7
Postby AB7 » Wed Feb 20, 2008 9:36 pm
Wun, you really want to save weight huh?
BTW I got my windscreen replaced for $180 by Novus. By far the cheapest, some other company charges between $240 to $320
GP
Postby GP » Thu Feb 21, 2008 10:52 am
:shock: Not for many years, Windscreens have been laminated since before 5's were made. It will not shatter
Graham
Juffa
Postby Juffa » Thu Feb 21, 2008 12:20 pm
I had two MX-5 windscreens replaced in Melb about two years ago for $146 each and they will do the work at your home or work. I believe they are called FX Autoglass. By the way for that price they will use a standard one type fits all seal. The original Mazda seal costs around $100 in addition to the cost of the glass.
FX Auto Glass
75 Allendale Rd
Noble Park
VIC 3174
ph: 0412 897844
J
Locutus
Postby Locutus » Thu Feb 21, 2008 12:26 pm
they still shatter into tiny pieces, but do a reasonable job of staying togeather because they are laminated.
depends on where the chip is located, but why replace the windscreen when you can get a small chip repaired for $50 or so with lifetime warranty?
AB7
Postby AB7 » Thu Feb 21, 2008 12:38 pm
Juffa wrote:I had two MX-5 windscreens replaced in Melb about two years ago for $146 each and they will do the work at your home or work. I believe they are called FX Autoglass. By the way for that price they will use a standard one type fits all seal. The original Mazda seal costs around $100 in addition to the cost of the glass.
FX Auto Glass
75 Allendale Rd
Noble Park
VIC 3174
ph: 0412 897844
J
Wow, that's cheap. Mine uses the 'standard one type fits all seal', looks quite good actually. Mazda charge $58 now for the OEM seals, still rip off though.
Re: I got a chiped windshield
Postby bruce » Fri Feb 22, 2008 5:20 pm
wun911 wrote:Anyone know where I can replace the typical glass windshield with a thin flimsy acrylic one?
You are kidding right?
Users browsing this forum: No registered users and 196 guests
