Soft top cable replacement on NB
bigdog
King of the kennel
Postby bigdog » Sat Feb 09, 2008 10:04 pm
Has anyone here done this? I have had broken tension cables ever since I've owned the car - they have always annoyed me just dangling there, so thought I would replace them... but I can't figure where they attach. I have studied the various guides on the big forum, and concluded that the riveted end attached at the red point marked below
- there were plastic tabs rivetted there with nothing attached, so I figured the cables must have broken off from there, but it seems from further investigation that they run right to the front of the hood as seen in this picture:
There is a hole in the side lining of the top right at the very front of the top and I can see the remains of the old cable there, so I assume I need to remove the top from the frame at this point to fit the new one. Can anyone point me in the right direction with this task? And can someone explain what the cables actually tension? :D
wun911
Postby wun911 » Sun Feb 10, 2008 1:14 am
every ounce counts
TieNN89
Postby TieNN89 » Sun Feb 10, 2008 1:28 am
what in the world does that cable actually do?
wun911
Postby wun911 » Sun Feb 10, 2008 1:18 pm
when my cable snapped only one side snapped...
You can tell when you put the roof on which side had more tension. I think it helps to hold the sides of the roof to the frame and keep it in tight shape.
U didnt notice any leaks when the cable was snapped tho.
every ounce counts
bigdog
King of the kennel
Postby bigdog » Sun Feb 10, 2008 1:29 pm
Ok... that's the cable i'm talking about... how do you get to the rivet point at the front of the hood?
green_comet
Car Detailing Guru
Postby green_comet » Sun Feb 10, 2008 8:13 pm
I think u need to remove the rubber around the window, then unscrew the metal plates behind.
wun911
Postby wun911 » Sun Feb 10, 2008 11:18 pm
when you replaced your roof dint the new roof come with new cables??
every ounce counts
bigdog
King of the kennel
Postby bigdog » Mon Feb 11, 2008 9:23 am
Just to clarify, I am not replacing the roof, just the tension cables on my existing 6 year old roof.
wun911
Postby wun911 » Mon Feb 11, 2008 10:29 am
Ohhh sorry I meant green comments new roof that he recently installed...
I was a nube and I managed to fixed this, it was even the first time I used a rivit gun. The only tool I didnt have was a very short philips head screw driver.
You will need this stubby screw driver to unscrew the spring that the cable is attached to.
The only other anoying thing was threading the new wire though the hole, took a couple of goes. (open and close the roof a few times as your threading the cable though helps a lot)
every ounce counts
green_comet
Car Detailing Guru
Postby green_comet » Mon Feb 11, 2008 11:04 am
Lol green comment, i think im going to change my name to that..
Andrew
Postby Andrew » Sat Feb 16, 2008 5:29 pm
Ajay
Postby Ajay » Sat Feb 16, 2008 6:16 pm
green_comet wrote:Lol green comment, i think im going to change my name to that..
hahaha :lol:
