Rolled Guards
Nickb
Rolled Guards
Postby Nickb » Fri May 18, 2007 1:57 am
G'Day,
I'm looking at getting my front guards rolled as the 17\" rims that I have rub a bit (yes, I know they are too big....). Been told by my local panel beater that the metal is quite thin so after rolling I may need to get the guards resprayed. Is this usually a problem?? Are there are different ways to get the guards rolled? I've basically been told that they use a dolly and hammer to fold in the lip, is that right? I thought there was actually a machine that actually \"rolled\" the lip?
Car is an NA6.....
Ajay
Postby Ajay » Fri May 18, 2007 7:24 am
your car scrubs with 17's??.. is it super low..
im running 17\" wheels and tein lowered suspension and i dont scrub.. is it all the time or just on speed bumps?..
in answer to your question.. i dont know.. sorry
Juffa
Postby Juffa » Fri May 18, 2007 7:53 am
Nickb
Postby Nickb » Fri May 18, 2007 10:17 am
Yeah, it scrubs over bumps. Left hand side is worse as it looks like someone has tried to bend the lip outwards and has made it worse... Suspension is standard (although old...), Tein Flexes are going in shortly, so it'll be lower....
Interesting on that site it talks about using a machine, thats what I would expect. May have to ask around a few other shops, just that this shop is only 50m from my house!
lowmiata
Postby lowmiata » Fri May 18, 2007 11:13 am
Nickb wrote:Yeah, it scrubs over bumps. Left hand side is worse as it looks like someone has tried to bend the lip outwards and has made it worse... Suspension is standard (although old...), Tein Flexes are going in shortly, so it'll be lower....
most wheel shops have them
they just bolt to your hub
and have a skate board wheel that runs around the inside gently folding the lip up
of note many places have them but most try to do it to fast and bite into the guard to far causing the cracking of the paint
your 17's shouldn't be rubbing though with stock suspension
i have mine lowered on 17's and i have onyl had problems when it was lower than it is now
What offset are the wheels?
as that could be the problem
EVI15 1998 to 2008
Nickb
Postby Nickb » Fri May 18, 2007 12:21 pm
I don't know the offset (can't see it marked on the rims), but it ain't standard.... definately part of the problem. Would like to change the rims, but with forking out for the Teins, it may have to wait... they do look good though.
Just found a mobile guy who will come out and do it with the proper tooling. $150 for the front guards, see how it goes.
BCHELR
Postby BCHELR » Sun May 20, 2007 9:06 am
i have 18s on the front and no need to roll fronts.
offset and width of the rim are your bigest concerns.
keep offset to +40 and width to tno more than 7.5 inhes 8s scrub like hell.
i also have mine lowered 1.5 inches on front which is perfect for 18s.
Guard roller.... dont know where your from but go see Ozzy tyres in hoxton 50 a gaurd and they know whwat they are doing
Users browsing this forum: No registered users and 110 guests
