Guess who has their car back? :D
Boags
Postby Boags » Mon Jan 22, 2007 2:08 am
Oh god, I made a mess Fuzzlet... :oops: That is so sexual. :twisted:
Boags
Fuzzlet
Postby Fuzzlet » Mon Jan 22, 2007 7:11 pm
Hooray for problems.....In yesterdays heat, I managed to boil the coolent......I let the car idle for a min (as I always do), but when I turned the engine off, heard this weird bubbling sound coming from drivers side under bonnet. Opened up the bonnet, and the coolent in the overflow tank was boiling :shock: I then left the car on (but engine off) with the radiator fans going for 2 mins in the hope that it would bring the temperature down, which it did.....I really hope PWR makes my radiator soon...
jules
Guitar Hero
Postby jules » Tue Jan 23, 2007 11:01 am
Probably a good thing. You top radiator looks like it's toast soon anyway.
Jules
Fuzzlet
Postby Fuzzlet » Wed Jan 24, 2007 11:10 am
jules wrote:Probably a good thing. You top radiator looks like it's toast soon anyway.
Jules
Haha when I looked at pics of the car (before I bought it) I though the radiator had rust on it....Then found out it uses plastic end tanks...Apparently the new radiator will be here next week, so problems should go away soon. Ive found that if its a warm day, after letting it idle for a bit, turn the engine off but let the radiator fan run for a minute helps things a lot
