NB/NA soft top clip compatibility
Curly
Postby Curly » Wed Oct 25, 2006 5:55 pm
Quick question.
A friend of mine has an NB8 (C I think) and one of her soft top latches isn't working properly - apparently it takes a few goes before it actually latches.
Is this a common problem?
She's been quoted $400 from a Mazda dealer for a new latch, which ... seems a little over the top.
Are the NA and NB ones compatible? I assume Mania would have a pile of them laying around?
kitkat
Postby kitkat » Wed Oct 25, 2006 6:02 pm
when you say it doesnt latch, is it because its not catching?
with our NA, on cold days it will take some effort to get the latch to grab, normally i have to give a good pull on the top so it allows the latches to get close enough to eachother.
I think the latches can be adjusted.
Juffa
Postby Juffa » Wed Oct 25, 2006 6:20 pm
I'm pretty sure that they are basically the same. Having said that I know that many NBs were suffering from clips that were worn out and the latch could actually release, usually with the car in motion. Not heard of this being a problem on the NAs for some reason.
If you do a search on the big forum you should find heaps of examples.
J
Curly
Postby Curly » Wed Oct 25, 2006 8:19 pm
kitkat wrote:when you say it doesnt latch, is it because its not catching?
I haven't had a look at it yet, but the impression I got was the it was latching fine, but not staying latched.
I was also under the impression that the adjustment only adjusted the tension on the roof, not the latching tension. I'll have a look when I get home.
Garry
Postby Garry » Thu Oct 26, 2006 9:37 am
It's possible to file a few mm off a stopper on the latch mechanism so that the latch doesn't come unlocked by itself. Do a search through the forum for instructions. Much cheaper than buying a new one and not much more work than replacing it with an NA one.
I thought the latches were changed slightly in the last of the NB's so they are not quite compatable with the earlier ones
irwin83r
Postby irwin83r » Sun Oct 29, 2006 11:53 am
i'd play with the adjusters a bit first. you never know it might just need a tighten. pretty simple to do.
Postby Okibi » Sun Oct 29, 2006 8:05 pm
They're piss easy to adjust.
If you can't work it out then bring her along to a club meeting and i'll do it for her.
The only issue is if they don't \"lock\" shut.
