1 person hardtop replace & remove?
- RobbieRat
- Vehicle: NA6 - Turbo
My technique is to unclip everything, then open both doors. Then get in the car so you are kneeling on the seat, kinda facing across the car but a bit forwards. grip both sides of the hard top where the tops of the widows are and use the back of youre neck to push up and take the weight of the Hard top,you need to get youre neck/shoulder in the center of the H.T right at the top of the rear window so you have got the weight distribution right Then simply stand up/back while balancing the H.T on the back of neck and shoulders.(handy to remove aerial before you start this)
hehe.
Sounds alot more complicated than it really is. the hardest bit is making sure you dont bang the H.T on anything. its not very heavy when its on your shoulders.
