So, it seems front wheel bearings wear at about the same rate as brake pads when you have a bit of power and 225 R specs.
What is the upgrade path from the standard wheel bearings?
Wheel bearing upgrade path?
- davekmoore
- pepejesus
Re: Wheel bearing upgrade path?
Brake ducts to help keep heat in the hubs down. Repack with good quality grease and matched diameter bearings.
Wait for these: https://www.miataturbo.net/race-prep-75/tapered-roller-bearing-hubs-its-happening-88149/
Or try these: https://www.mazdamotorsports.com/webapp/wcs/stores/servlet/DisplayRacerStoryView?storeId=10001&catalogId=10001&langId=-1&source=RIGHT_HOME&uniqueId=11362
2004 SE - stock ECU, stock engine, BEGi intake, FMIC, BC Racing 10/6, 15x8s, 225/45 NT-01s
Barbagallo long: 70.488
Barbagallo short: 58.999
- davekmoore
Brake ducts, done. Wilwood 6 pots, done. Polymatrix H compound pads, done. Driver ability/training to do less braking, not done.
Flyin' Miata do a "blueprinted" version of standard hubs at less money than an OEM one, but still with ball bearings, so I'm not too hopeful of a solution there.
So I may need to go with the roller bearing ones, even though there's a suggestion they are still in development mode.
Here's hoping.
Here's hoping.
- Hellmun
- Vehicle: NB8B - Turbo
Terry Bosnjak makes billet ones for mx5's using tapered roller bearings. Can't rate him and his work high enough. http://www.terrybosnjakengineering.com.au/billett-hubs
They're serious race parts and not cheap though. I was fed up by about the 8th front hubs failure....so I have a set on my car.
- davekmoore
Thank Hellmun.
Sent you a PM Dave...
- Nuddy
Is this for all models?
NC 2.5 race/tarmac rally car
NC 2.0 race/tarmac rally car Sold
NB8a Sold
Patrol GUIV TD42tdi for touring and towing
BMW R1200R for daily ride
NB8a Sold
Users browsing this forum: No registered users and 58 guests
