Can I attach 6 point nut straps to LATCH anchors?
Racing Logic
Postby Racing Logic » Wed Jan 27, 2016 9:05 pm
The later model NBs have LATCH anchor points for child seats. They are reinforced brackets bolted through the rear bulkhead at about the height of the seat bottom which attach to some child seats overseas. As they are a reinforced safety mounting point Can I attach clips of my 6 point harness nut straps to LATCH anchors?
Jon
89 NA Sold
98 NB Sold
04 NB SE Turbo fun
http://www.SurfFX.com.au
Apu
Re: Can I attach 6 point nut straps to LATCH anchors?
Postby Apu » Wed Jan 27, 2016 9:13 pm
Only if you want crushed nuts.
Google harness mounting points and that will give you the recommended locations.
Racing Logic
Postby Racing Logic » Wed Jan 27, 2016 9:19 pm
Looks like a big NO. Can't be more than 20 degrees back from vertical
Jon
89 NA Sold
98 NB Sold
04 NB SE Turbo fun
Postby hks_kansei » Thu Jan 28, 2016 9:47 am
I'd just go to any race supplier and buy some eye bolts (or regular harness bolts) and some spreader plates.
Drill a hole in the floor wherever you want the belt to mount, then screw the eyebolt into the spreader plate/captive nut that you place under the car (few dabs of sikaflex stop it moving while you screw it in)
I did this to put an NA6 style seatbelt stalk into my NB
Return to “MX5 Motor Sport”
