Passenger side brake lockups
Posted: Fri Aug 15, 2014 1:00 pm
I'm running a NA6 with DBA brakes, Ferrodo pads and a biasing valve (fully open). I am consistently locking the front left under heavy braking especially on hill climbs where the tyres and brakes are cold.
Is this just because I'm sitting on the right of the car so there is less downwards weight on the passenger side so less friction? I have bled the brakes a few times so it shouldn't be an air pocket. What can you do to fix the issue other than not braking so hard?
Does upgrading to a larger brake (NA8b) help with brake control? Other than this lock up issue, I find when I'm tracking the car, the brakes are excellent and I think I'd rather keep to the lighter brakes rather than have extra weight on each corner.
