6ul Wheel Failure
mazmad
6ul Wheel Failure
Postby mazmad » Mon Jan 21, 2013 8:04 am
Anybody seen anything like this with 6ul's before? I am running them and was considering another set, hoping this is not common!!
Hjt wrote:Image
Picture tells a thousand words.
Footage from my vehicle and Phil who was following will eventuate.
Basically turned into turn 3 heading uphill at Wakefield Parkway on my second lap of the second session, the unloaded rim decided to give way. The outside is believed to have torn first, the centre made contact with the ground and eventually fell apart. I slide for approx.. 10 metres on my right rear rotor.
No apparent damage to engine or vehicle, pride is bruised.
Thanks for all who asked if I was okay and helped pick the car up so we could get a jack under it.
Drove home on a spare, many thanks to Mr Green for that, I do appreciate it.
This is just a warning for what can and likely will happen at some point in time.
regards
Hayden
Apu
Re: 6ul Wheel Failure
Postby Apu » Mon Jan 21, 2013 9:54 am
This is the first one I've seen, but I've heard of it and spoken to someone who has. I've mentioned it in the other thread, and was only speaking with Suspense about this exact thing happening the week before.
So it appears not to be a one-off, and as Hjt mentioned in his thread, please go and check your wheels carefully.
Apu
Postby Apu » Mon Jan 21, 2013 10:34 am
Here's Suspense's link from the other thread http://forum.miata.net/vb/showthread.php?t=290214&highlight=6UL+failure&page=19
I would suggest though that moderators close this thread as it is effectively repeating what is being covered in Hayden's original thread?
mazmad
Postby mazmad » Mon Jan 21, 2013 4:03 pm
I wanted to make sure that the motor-sport crowd were aware of it (hence posting in the general motor sport section).
But yeah best post on the one thread, as listed by apu above.
mazmad
Postby mazmad » Mon Jan 21, 2013 4:04 pm
project.r.racing
Postby project.r.racing » Tue Jan 22, 2013 8:58 am
Bugger! Although uncommon, it does happen.
zoomzoom
Postby zoomzoom » Tue Jan 22, 2013 10:26 pm
Do you know which generation the wheels were? I know from gen1 to gen2 they changed the casting process presumably to minimize the chance of included defects but I am not sure what the difference is with the gen3?
Tim
Hjt
Postby Hjt » Tue Jan 22, 2013 11:27 pm
gen II.
mazmad
Postby mazmad » Sat Mar 30, 2013 4:16 pm
Another 6ul blown at the FOSC today. Don't know if he is turbo'd (and therefore how much power he was putting down).
Was turn 10 onto the straight. Poor bugger.
Postby manga_blue » Sat Mar 30, 2013 5:33 pm
I don't know if turbo or not turbo would make much difference. The torque on the fronts in hard braking would be far higher than the torque you'd ever get from an engine.
Suspense
Postby Suspense » Sat Mar 30, 2013 7:00 pm
What sort of vehicle and lap times?
outbreakmonkey
Postby outbreakmonkey » Sat Mar 30, 2013 7:03 pm
That's not a good advert for the product. The MX-5 isn't exactly a heavy car. I think I'll be purchasing Enkei or SSR.
mazmad
Postby mazmad » Sat Mar 30, 2013 7:48 pm
Suspense wrote:What sort of vehicle and lap times?
Mx5. He qualified with a 1.10.9
Good call on fourth for the hill too thanks Spence :D
Edit....as with Hayden's also outside rear.
greenMachine
Postby greenMachine » Sat Mar 30, 2013 9:13 pm
What size rim/tyres? Slicks?
:mrgreen:
mazmad
Postby mazmad » Sun Mar 31, 2013 3:25 am
Think 225 semis. 15s.
Return to “MX5 Motor Sport”
