NA or NB Fire Extinguisher mount adapted for NC
LuckyCat
Postby LuckyCat » Thu Dec 27, 2012 2:19 pm
This is a small project which involves using the Extinguisher mount from MX5 Mania and adapting it to the NC.
You could use the bar as posted by Regie on this forum as a basis, then to obtain 2 x 45 degree acute angle brackets. These are not easy to find but I
did locate several sources.
So here is the picture of my idea. The bottom of the Mania plate should rest nicely on the carpet.
At the moment I have a Mania mounting and I am waiting for the acute angle brackets......
cheers
Chris
Re: NA or NB Fire Extinguisher mount adapted for NC
Postby Regie » Thu Dec 27, 2012 6:32 pm
should the extinguisher be mounted on the other side of the plate??
looks to me like it will be sitting in mid air.
I do have 1 bracket left over for the NC is you are interested
Postby Regie » Thu Dec 27, 2012 6:35 pm
I need a NB to get some brackets made up :)
LuckyCat
Postby LuckyCat » Fri Dec 28, 2012 6:55 am
Regie wrote:should the extinguisher be mounted on the other side of the plate??
Sorry Regie, the drawing wasn't to scale. I am hoping it will rest nicely on the carpet,
chris
craigj
Postby craigj » Tue Jan 29, 2013 12:34 pm
Hey Regie,
Do you still have an NC bracket?
Craig
Return to “MX5 Motor Sport”
