I want to put a sparco sprint as my drivers seat in my NC.
I believe there is some sensors connected to the standard seat.
If i install the sparco seat will everything still work as it should if i install the seat properly?
NC sparco sprint seat
Re: NC sparco sprint seat
You will get a permanent airbag light, can be fixed by cheating the sensor with a resistor.
deviant wrote:You will get a permanent airbag light, can be fixed by cheating the sensor with a resistor.
does that mean the airbag with not work?
Not sure. If the light is on I believe it will not but if the sensor has been tricked...no idea. I am guessing fooling the sensor makes it think someone is sitting there so it will work. just a guess though.
- Guran
- Vehicle: ND - 1.5
Not sure - do NCs have side airbags in the seats? If so, fitting a replacement seat without airbags fitted would probably be illegal for road use.
- Regie
- Vehicle: NC - V8
Guran wrote:Not sure - do NCs have side airbags in the seats? If so, fitting a replacement seat without airbags fitted would probably be illegal for road use.
yep they have seat bags
Regie wrote:Guran wrote:Not sure - do NCs have side airbags in the seats? If so, fitting a replacement seat without airbags fitted would probably be illegal for road use.
Well i can forget about the sparco then, not worth it.
New cars are really starting to sh*t me with all these electronics, such a pain to modify. I must be getting old
- Guy_Coles
deanb90 wrote:Regie wrote:Guran wrote:Not sure - do NCs have side airbags in the seats? If so, fitting a replacement seat without airbags fitted would probably be illegal for road use.
I've got a Sparco EVO 2+ in mine. Yes, you lose the side Air Bag and that's always a gamble in the case of driver's side intrusion. I have a funny feeling that it's probably a defectable offence as you're not allowed to disable an air bag, I seem to remember Guran commenting on this some time ago as well as above.
I've never been pulled up yet (caveat - I'm in my late 40's so not quite seen as the young hoon by the Bronze), The seat is a pain in the ass to get in and out of but once you're in - you're not going anywhere. The warning light can be fixed by a 2ohm resister or a piece of well placed race tape....
Worst case scenario, it's 5 bolts, ten minutes and one connector to replace on race day.
2006 Black NC Soft Top with lots of Mods -
WP: 1:12.26 , SMP South 1:106.25 - 11th outright in Victorian 6 Hour 2015
http://privasec.com.au//
Users browsing this forum: No registered users and 112 guests
