Toyo pressure
olboy
Toyo pressure
Postby olboy » Fri Nov 13, 2009 5:26 pm
Just after a bit of advice. I just bought some new toyo 888s and I need a starting point for pressures.
I'm doing a hillclimb this weekend and thought 28 front and 30 rear would be ok.
What do you guys with these tyres use.
Any advice would be appreciated.
Thanks Olboy
tbro
Toyo pressure
Postby tbro » Fri Nov 13, 2009 10:03 pm
Olboy,
Try 25 cold and work from there.
Terry
JBT
Toyo pressure
Postby JBT » Fri Nov 13, 2009 11:54 pm
Depends on the hillclimb length. You mostly start with cold tyres and finish with warm (not hot) ones. I'd be going for a mid range pressure all round and go from there.
Toyo pressure
Postby manga_blue » Sat Nov 14, 2009 6:36 pm
On a track you start from 24-26 hoping to warm up to about 30 for best grip. On a hillclimb you might as well start at 30 coz there's usually no time to gain heat.
Ever notice how rare it is to get everyone agreeing on anything in this forum? :D
Fatty
Toyo pressure
Postby Fatty » Sat Nov 14, 2009 7:20 pm
i agree with manga_blue.. on both counts :lol:
fish
Toyo pressure
Postby fish » Sat Nov 14, 2009 11:30 pm
yeah depends on the length i am assuming pretty short ....so start at 29 I reckon
born again 1994 NA8 2F RACE CAR ....No 42
olboy
Toyo pressure
Postby olboy » Sun Nov 15, 2009 4:46 am
Thanks Fish I'll go with that
olboy
Steve - Toyo Tyres
Toyo pressure
Postby Steve - Toyo Tyres » Fri Nov 20, 2009 2:52 pm
Most Hill-climbs are < 60secs. You can expect only 2 - 3psi pressure change.
29 psi is spot on.
olboy
Toyo pressure
Postby olboy » Fri Nov 20, 2009 3:08 pm
Started with 30 alround, ended up with 27 front and 25 rear cold.
Pressures were rising by 1& 1/2 lb on the outside wheels and the car was a oversteering a little so I probably need to adjust the front bar up one hole.
Its on soft now and the rear is on hard.
thanks for your help
olboy
Return to “MX5 Motor Sport”
Users browsing this forum: Bing [Bot] and 3 guests
