195 50's & NB8A rims or new 15 x7's & 205's?
tk421
Postby tk421 » Sun May 20, 2007 1:45 pm
Hi.
I'm thinking of getting some r888's for the track instead of ruining a set of Michellin PP2's in 205 45 for the road which I am planning to get for my 16\" wheels shortly.
I have a set of NB8 rims sitting around and doing nothing so thought some 195 50 R888's might go well on those. Alternatively I could buy a set of Mania's cheap 15 x 7's and put 205 50's on them. Would I notice any particular difference between them? (other than less track of the narrower wheels).
Obviously if I don't buy wheels well thats $600 saved and I guess the 195's will be cheaper as well so no bad thing. That said if 205's are worth it then I don't mind spending the $$.
Your thoughts?
Steve
98 NB8A, Mania CAI, Eibachs and Bilsteins, Whiteline brace, Starcorp's, DBA Slotted and asstd bling, FM butterfly brace. FFS coldside and the whiiiinnne. Now 138rwkw (Glory Run :) ) More with tuning.
http://users.tpg.com.au/usethe4c/Green+Machine.jpg
Boags
Re: 195 50's & NB8A rims or new 15 x7's & 205's?
Postby Boags » Sun May 20, 2007 3:34 pm
tk421 wrote:Your thoughts?
My R888s are 205/50/15 and are on 15x6.5 rims...
Best of both worlds for you Steve; keep your rims (and your money) and get more rubber on the road. :mrgreen:
Boags
tk421
Postby tk421 » Sun May 20, 2007 3:55 pm
Boags
Thanks for that Mate. The NB8 wheels I think are only 6" wide though. Would the 205's create a bit of sidewall bulge and as a result less steering feel?
Samselectrics
Postby Samselectrics » Mon May 21, 2007 10:17 am
Boags
The NB8a wheels are 6.5 and will fit your tyres fine. And due to the fact that they're smaller, they'll more than likly be lighter.
Sam
#35 Someone spent billions building these roads and you have to drive on the grass!
Slugoid
Postby Slugoid » Tue May 22, 2007 12:03 am
According to this, you can fit 225's on a 6\" wide rim if you're game enough :lol: .
205's on a 6.5\" rim would be perfect. I'm running 6\" for my track rims and I'm stuck with 195 tyres. Not willing to try 205 tyres on them, even though I can. How much more grip does 205 tyres have over 195, in terms of R-comp tyres like R888's?
irwin83r
Postby irwin83r » Tue May 22, 2007 12:10 am
my NB8A rims were 15x6 standard.
Slugoid
Postby Slugoid » Tue May 22, 2007 2:08 am
irwin83r wrote:my NB8A rims were 15x6 standard.
http://www.miata.net/faq/wheel_weights.html
I'm not sure if that's right, but according to that the NB8A rims ('99-2002 Sport 5-spoke alloy) are indeed 15X6.
tk421
Postby tk421 » Tue May 22, 2007 8:54 am
Yep as far as I know they are as well. They are in my parents garage about 100k's away so not a quick check!
Boags
Postby Boags » Tue May 22, 2007 11:54 am
Well, in that case, forget I spoke! :mrgreen:
But, if you're going to buy rims - 15x 6.5 will most likely be lighter! 8)
kula
Postby kula » Tue May 29, 2007 11:17 pm
i run 195s on 8s.
slammer
Postby slammer » Tue Jun 12, 2007 1:05 am
I run 203's (195 on sidewall 203mm in fact) on only 6 inches :shock: [/i]
http://members.optusnet.com.au/~slammer NA6A 16.1 1/4 , 1:13.57@Wakefield
Return to “MX5 Motor Sport”
Users browsing this forum: No registered users and 203 guests
