As the title suggests?
I've had the alignment done by Fulcrum to \"track spec\" and changed the brake fluid only to discover that the RT615's weren't holding up as well as I thought they were.....the wear indicator is less than 1mm away
What do yall in the know think of these settings for an SE with stocko suspension?
BNE - Time Attack - 17.05.07 - Who's going??
- ASE05
Sing that song, puff all night long.......
- JBT
- Brad
- rhysk
I actually go slightly the other way, a bit less toe on the front (0 - 0.5mm toe in each side) and between 1 - 2 toe in at the rear. If you have lots of grunt, you can get away with even more toe in at the rear, gives you half a chance to get onto the power earlier out of the corners. Camber seems fine for a road car. With that sort of camber, I would have almost expected a bit more caster. But each car is different, that could be as much as they could screw out of yours. Some tyres need more camber than others, take a good look at how yours are wearing too.
Motorsport is a disease, where the only cure is poverty!
The ego writes cheques that skill can't cash - DJ
- Boags
- fish
not gonna be at this one ....will be racing top gear on sunday 20th but ....come on out if you wanna se a lot of MX 5 's dicing at very close quarters with each other.... eapecting between 15 and 20 cars for this one
born again 1994 NA8 2F RACE CAR ....No 42
- ASE05
I haven't had a chance to drive in anger yet on the new settings so I guess I'll find out on Thursday
I had no idea what settings to get so I left them to their own devices. I figured that I'm struggling to get 8 - 12000km outta the tyres anyhow so what the heck, may as well get it to handle while it's chewing 'em out
I did find in the brief drive I had today after cleaning the engine bay that it seemed to be more stable through corners/roundabouts than before and a lot less skittish if that makes sense. It was pretty badly outta whack for a while though so I guess that could be expected.
JBT/Boags, you're both weak!!
Anyone else going? I kinda hope the rain stays at bay for the day though.......
- Brad
Users browsing this forum: No registered users and 177 guests
