quick release steer hubs
irwin83r
Postby irwin83r » Mon Mar 19, 2007 5:56 pm
not sure if i should ask here or in another section.
but i was wondering if anyone has used a quick release steering hub before on the track and or road?
reason im asking is id really really like to run a smaller diameter wheel to get a bit more room when racing but as the car is a NB and has an air bag standard i cant change the wheel legaly on the road. so what im wondering is can i run a smaller.. none standard wheel on the track?? and also would this be possible with a quick release hub? or are they not road legal??
cheers
irwin
bigdog
King of the kennel
Postby bigdog » Mon Mar 19, 2007 9:54 pm
Quick release hub will not mate to the NB wheel so no real advantage there, and if you're putting a smaller wheel on you don't need to remove it to get in and out, so no advantage there either. And any mod to the steering column on an NB would be 'engineer' territory... Short answer - don't do it. :D
kula
Postby kula » Mon Mar 19, 2007 10:24 pm
about the only decent QR hub is a works bell, they are about $650.
you have to get rid of the airbag system to use it.
there isnt an interchangable one that i know of which allows the use of airbags.
irwin83r
Postby irwin83r » Wed Mar 21, 2007 11:47 pm
damn...
well... next question.. can i get the standard wheel retrimed and made smaller??
kula
Postby kula » Thu Mar 22, 2007 9:03 am
doubt it.. but it might be possible.
id maybe look at smaller airbag wheels from other manufacturers,
try an evo wheel?
irwin83r
Postby irwin83r » Thu Mar 22, 2007 7:42 pm
kula wrote:doubt it.. but it might be possible.
try an evo wheel?
ahh never thought of that..
will look into both
Return to “MX5 Motor Sport”
Users browsing this forum: No registered users and 189 guests
