NB8a race set up
travyMX5
NB8a race set up
Postby travyMX5 » Fri Feb 23, 2007 10:02 pm
hey all,
just wanting peoples opinions of what a good street going track car set up for an mx is??
i am thinkin bout koni /lows king pack??
LSD?
Front brake upgrade?
Full FM chassis brace?
semi slicks?
PWR radiator & oil cooler combo?
Upgraded plugs and leads?
Any feed back on what works what doesnt??? or any suggestions??
Already have JDM spec bilsteins but they are too high i also have 26mm f and 16mm adjustable r sway bars, front strut brace, BD roll cage, K&N filter in std box drilled out with cold air ducting from front bar, 2.25\" headers back exhaust (no cat) , extinguisher and sparco sprint seat....
anyway any thoughts would be good???
CT
Postby CT » Sun Feb 25, 2007 7:09 am
Depends what the purpose is? Just for track days, all you need is decent brake fluid - motul rbf600 is a good one, decent pads, like Hawk HP or HPS, braided lines are a good idea as well. Konis and kings are fine for a start, Teins are better or just get a decent set of springs for the bilsteins you already have. Heasmans or East Coast Suspension can revalve the bilsteins which will make them much better especially matched with either kings or eibach springs. A torsen lsd is a nice thing too.
If the mechanicals are in good nic now and you aren't upgrading them, you shouldn't need to do much else. Decent tyres are where the times are so get a set of 15x7s and wack some 205/50 Toyos R881s for a start or dunlop D02 or the new D03 if you want the best tyres. 8)
Return to “MX5 Motor Sport”
Users browsing this forum: No registered users and 192 guests
