im not a current mx5 owner, but i am looking at getting a set of std na8 mx5 wheels to put some semi's on for track duties.
my question is, do you think this is worth while? at the moment i have heavy 16x7\" wheels with 205/40R16 Federal 595 tyres on (pretty sticky for street tyres). do you think its worthwhile going to some 185/60R14 Toyo R888's on the NA8 wheels? will i see a significant increase in grip? or only small? given the smaller width and taller profile?
hope this all makes sense. thanks
semi's on std 14\" rims?
- Bevan
- kitkat
well from what i hear the stock mx-5 rims are meant to be very light so theres one good point there.
IMO i think you would be better off with the smaller rims, your using a startet which is small so you dont really need things like \"big brakes\" or \"big rims\"... ofcourse i could be completly wrong so ill wait for other to confirm my thinking.
- Boyracer
- MX-5 Encyclopedia
- MVZOOM
- Location: Road signs are so hard to read when you are driving quickly....
kitkat wrote:well from what i hear the stock mx-5 rims are meant to be very light so theres one good point there.
IMO i think you would be better off with the smaller rims, your using a startet which is small so you dont really need things like "big brakes" or "big rims"... ofcourse i could be completly wrong so ill wait for other to confirm my thinking.
Prob not a bad call, however you're going to find it tricky to get smaller semi slicks than 14"... even 14's are getting hard to find!
Cheers - Mike
'97 LE [R.I.P] - 240kW Mazda3 MPS, BMW E46 M3, Lotus Exige S
- StanTheMan
Re: semi's on std 14\" rims?
jezza323 wrote:im not a current mx5 owner, but i am looking at getting a set of std na8 mx5 wheels to put some semi's on for track duties.
my question is, do you think this is worth while? at the moment i have heavy 16x7" wheels with 205/40R16 Federal 595 tyres on (pretty sticky for street tyres).
are you talking Federal 595RS?
regardless....it all depends how much you'll be racing. Also if you like a spirited cruise on weekends. Keep the federals for that. Use the 14's for a dedicated racing set.
also 15" you can get the NB8A's which are also vey nice rimms....I think you can pick up a set for around $400. Plenty of good choice for sticky rubber.
certainly try to stay clear of the 16" for racing. It reduces your choice of tyre big time.
- Vehicle: NA8 - Turbo
just an update for ppl interested
got the 14\" NA8 wheels
this is them on the car with the shot tyres that were on em
in the next 2 weeks i will have some silverstone FTZ-RR tyres in 185/55R14 on them, cant wait to try them out on the track!
the 16's i have are not the 595RS, just the old SS595, now the 595, they will stay my street wheels/tyres
the silverstones in 185/55 R14 are just a tad over $200ea and are supposed to slot in somewhere between toyo's and yoko's on the wear/grip levels.
so they wont wear as quick as toyo's but dont need to be warm before getting grip like yoko A048's
i will let you know what i think when i have them, but i havent used semi's before so i wont have anything to compare against!
Users browsing this forum: No registered users and 115 guests
