Anyone Tried the A048 on an MX5 ?
Daz
Postby Daz » Tue May 09, 2006 8:07 pm
Still hunting for my next tyre and noticed that no-one seems to run the yokohama A048 ? Any comments ?
The Toyo R888 are $100/corner cheaper.... maybe thats why :)
Silver SP - PSS9, 1:10:58
Samselectrics
Postby Samselectrics » Tue May 09, 2006 8:13 pm
Are they the replacement fo the AO32R. If So Craig is running them down here in Mod class and loves them, though they are now bald (but only on the outside :mrgreen: ).
#35 Someone spent billions building these roads and you have to drive on the grass!
Postby orx626 » Tue May 09, 2006 8:17 pm
I use A048R on the front of my 626 and the 888's on the rear. The A048's have a treadwear rating of 60 where as the 888's are 100. ie. so they are somewhat stickier :twisted: .
Because my 626 inherently understeers (only slightly after suspension mods) I find that the extra stick available at the front really improves the balance of the car.
I can certainly recommend them.
rain902
re
Postby rain902 » Thu May 11, 2006 3:45 am
lurve my 048Rs.
the 32r is an old design casing - its been around for years and years (A008R) , the 48R is stiffer in the sidewall. the support you can get from traction tyres is superb as well - anything you ever want to know about setup and pressures is there for the asking...
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
Matty
Postby Matty » Thu May 11, 2006 9:43 am
orx626 wrote:I use A048R on the front of my 626 and the 888's on the rear. The A048's have a treadwear rating of 60 where as the 888's are 100. ie. so they are somewhat stickier :twisted: .
Comparing treadwear ratings from different manufacturers is fallacious... There is no set standard.
Postby orx626 » Thu May 11, 2006 9:55 am
That explains why a 215/45 R16 Falken RT215 has the same section width as a 195/50 R16 Yokohama A048R :shock:
rain902
Postby rain902 » Thu May 11, 2006 12:21 pm
Samselectrics wrote:Are they the replacement fo the AO32R. If So Craig is running them down here in Mod class and loves them, though they are now bald (but only on the outside :mrgreen: ).
time for a camber adjustment?
Return to “MX5 Motor Sport”
Users browsing this forum: No registered users and 188 guests
