Terratrip probes
Fra66L
Terratrip probes
Postby Fra66L » Mon May 08, 2006 8:14 am
For those running rally computers for classic rallies, what kind of probe are you running?
I'm thinking the generic gearbox probe would be easiest but perhaps the wheel \"bolt\" probe on the front wheel might be more accurate when one spins one's wheels....
Thoughts?
T
The Green Meanie - Grace Green NB8A
Veilside - It's Japanese for UGRY!
mazlot
Postby mazlot » Mon May 08, 2006 9:28 am
It should be able to be run from the back of the electronic speedo, both ours and Abyss' does
Jeff
Farken Gruven
Fra66L
Postby Fra66L » Mon May 08, 2006 9:32 am
Thank Maz,
Do you use a probe or just wire it directly?
DCMau
Postby DCMau » Mon May 08, 2006 9:45 am
mazlot wrote:It should be able to be run from the back of the electronic speedo, both ours and Abyss' does
Jeff
And mine. :D
Its wired directly to the loom. Just dont use the "other" orange wire like Abyss did. (ducks for cover)
mazlot
Postby mazlot » Mon May 08, 2006 9:50 am
You will need the proper probe wire, see GP Cars for it.
Its wired directly to the loom. Just dont use the \"other\" orange wire like Abyss did. (ducks for cover)
I thought that was a secret :lol: Oh well, nothing is sacred here is it :!:
Farken Gruven
DCMau
Postby DCMau » Mon May 08, 2006 9:57 am
I am not mentioning where the wire is and I did forget about the probe :oops: although for the price I shouldn't have.
Abyss
Postby Abyss » Mon May 08, 2006 11:59 am
Fra,
I am using a 3 wire probe as the others have said which wires directly into the loom.
They are about $50 just for some pieces of wire from GP Cars! (everywhere as the same price)
Don't connect it to the wire GP Cars tell you to, I'll have a look and let you know which is the correct one.
10AE #5522, Blue, the only colour to have. Every K over is a thriller
DAJ333
Postby DAJ333 » Mon May 08, 2006 1:46 pm
I'd always recommend using the proximity switch type probes, counting off a non-driven wheel for any Terratrip. For AWD rally setups always off the front wheels works ok. They're pretty easy to mount inside a hub.
For insurance I'd set up a probe on either side as the switches do have a life and they do sh*t themselves right when you least want them to. When one goes, merely hit the switch and start counting off the other side.
The speedo drive isn't my favoured setup as it is prone to the wheelspin factor, which in reality is pretty marginal anyway. With experience you'll find that you make allowances for wheelspin in wet or slippery conditions.
Of course, back in the 'good ol' days', we'd be switching the Haldas on-off-on in wet crappy conditions, then the cable drive would break, or the gears would jam, but they're a whole bunch of other stories...
Ted
Postby Ted » Sun May 21, 2006 2:01 am
DAJ - gone are the days when maps were older than the Haldas.
BTW if any of you want me to pick anything up from Demon Tweeks, just ask. Not saying I will do it though, the 2 belts, 3 Terratrips, 2 seats, 5 OZ wheel, Elise etc may just attract some attention at customs
Motorsport is a disease, where the only cure is poverty!
The ego writes cheques that skill can't cash - DJ
Fra66L
Postby Fra66L » Sun Jun 11, 2006 6:56 pm
Well, I've got the binnacle apart and the back of the guage cluster sure it purty :roll: .
The only \"orange\" wire I can find is in the one black connector (closest to the driver's door and it's more of a tan colour. Is this the one I should be connecting to the end of my 3 wire probe?
Thanks guys
T
DCMau
Postby DCMau » Tue Jun 13, 2006 9:38 am
That would mean that I would have to pull mine apart to check. :shock:
Fra66L
Postby Fra66L » Tue Jun 13, 2006 11:57 am
Thanks Dave but not to worry. I got it sorted late last night.
Found a PDF of the guage cluster on the net and it was in fact the one I mentioned in my last post. Only down side is that it doesn't seem to register anything unless you're going faster that walking speed (usually not a problem :mrgreen: ).
Just need to reinforce the mount now and I'm set...
T
Abyss
Postby Abyss » Tue Jun 13, 2006 2:10 pm
Tony,
The faster than walking speed issue may just be your calibration. Have you calibrated the Terratrip yet?
Return to “MX5 Motor Sport”
Users browsing this forum: No registered users and 208 guests
