Anyone running Toyo R888's, opinions please
- Red Baron
Subject says it all.
Am running RA1's that have scrubbed down and they are now coming into their own, but need something to replace the DJ01's for Supersprints this year, was thinking the R888's.
Can't use the RA1's as they are not available in 195/50/15's, but the R888's will be shortly.
baron
baron
Red
True Red NC Touring, Tein's, sways, beatrush chassis suite, roadstersports exhaust, starting to steer like a sports car, and stop like a bee with Hawk pads and DBA4000's! And still the wife's shopping cart, "Gold"
- justinfox
They're awesome!!! Great in the wet too. Go a little gummy after 5 hard laps but that's the same with any tyre. Had them on for a fair few k's too (my car is a daily driver) and lasting well. 14inch I have at $800 a set.
JDM Style Tuning Japanese car lovers club.
- Craig
- Vehicle: Non MX-5
- StanTheMan
- Red Baron
just courious what you were running at the wety wakefield in oct 2005
Yoki AVSES100's, about 50%, they are hopeless in the wet, and to be honest pretty ordinary in the dry too. Good when you first scrub them but down hill from there.
R888 would be worth a second or two over the RA-1's at WP due to it's solid tread pattern.
Only when both are new, once the RA1's are scrubbed the advantage would be lost, but I will give it a try anyway as I am very likely running R888's for Supersprints this year. That is once CAMS gets their stuff sorted. Interestingly a lot of RA1's are pre scrubbed and used as semi slicks.
baron
Red
- Craig
- Vehicle: Non MX-5
Red Baron wrote:once the RA1's are scrubbed the advantage would be lost
True, even with mine being knackered now they still hang on quite well.
*** Audi Q5 55 Sportback - HYBRID! Zero -100 in 5.3 seconds!
- Red Baron
Will be interested in your comments Dubly.
So how much track work do you do?
I would have thought that most R rated tyres would be far to noisy, I know the DJ01's are a nightmare on the road.
If you want something that is quiet (well reasonably), and grips like hell on the road you should try the RA1's, no warm up, grip from go and on the road wet or dry they are fantastic.
baron
baron
Red
- Red Baron
Had a set of 195/50/15's fitted this morning. Seem pretty good so far, just a run down the M4, suprisingly quiet
Doing a day at Oran Park tomorrow so will post my impressions.
baron
baron
Red
- Red Baron
- StanTheMan
- Red Baron
Sorry Daz, Had a party going on and a few reds under the belt.
Thanks Craig, the list tells the story.
At the moment there is GG compound, G is available on special order I beleive but Steve will run through this Wednesday Night at the Tech Talk.
First impressions are very good.
We ran the South Circuit today, but no timing so I have no idea.
The grip levels were superior to the DJ01's I was running last year, but they had been used so this is not a direct comparison.
Under braking, they just hung on, mid corner grip brilliant.
For the price you get a pretty good wigit that I think will work exceptionally well for supersprints, grip level cold are terrific and I could not get them to go off over 5 pretty hot laps.
baron
baron
Red
- red63sprint
Would they be a waste for primarily road use on a basically stock Clubman?
Eg - even stock 14 inch rims...
David
Would ya get more than 10,000k's out of a set?
David
1993 Clubman, Mx5plus roll bar
Autotechnica seats, Revalved Bilsteins
Fatcat Motorsport adjustable suspension
Espilier springs, Whiteline front bar.
