takai wrote:If you are talking Pis then ill presume that you are ok with some form of setup and programming. If you are, then you should be able to do all your logging through the PiDash using TunerStudio or similar. TunerStudio can take your CAN inputs from the MS3 Pro, and provide shift lights and engine vitals. I believe they are in the works of allowing for a lap timer as well. The Pi setup with TunerStudio has to be one of the most expandable units out there, and the community is always adding new plugins to do different things.
However, with expandability and flexibility often comes lack of reliability and analysis. I haven't been able to find much that allows for motorsport oriented log analysis, such as CircuitTools or RaceStudio etc.
Nope, I have no idea about this stuff, but if I can buy $150 worth of PI stuff, and connect it up to the MS3 to display the engine vitals and shift lights to start with, then I'm willing to learn
I can connect other sensors and a data logger at a later stage when time and money permit.
Tim_cyc03 wrote:Motec C125 - you will probably never need another dash again, and it does everything you want. And the software is simple to use.
$3500 for the dash and Level 1 logging capabilities. Way outta my budget
