Which data / track app do you use?
Re: Which data / track app do you use?
Postby Magpie » Fri Apr 17, 2015 9:49 pm
Thanks Dan I will look at the Aim stuff. I want to make a very informed decision before I commit to a replacement to the innovate. However, I'm trying to get seat time not play time with the car.
I have uploaded some of the VBO files that I have for various tracks I have been slowly around. Be great if others can as well.
madjak
Postby madjak » Sat Apr 18, 2015 8:10 pm
Snowmotion wrote:From what I have read about this External GPS is that it is used a lot in the aviation industry where most flights are at rapid speeds, but I imagine in the aviation industry there is no a lot of rapid change of direct or speed.
I will keep reading....
Are there any reasonably priced external GPS that you can recommend that will work with an iphone or ipad?
There is a DIY external 10Ghz GPS that connects via bluetooth and works with most lap timers. I know it works with Android so I assume it will work with iDevices too. Can build it yourself for around $30.
If people are interested one person could order all the required parts and then mail out kits. I was going to try it once I've finished all my other projects.
Snowmotion
Postby Snowmotion » Sat Apr 18, 2015 10:24 pm
madjak wrote:There is a DIY external 10Ghz GPS that connects via bluetooth and works with most lap timers. I know it works with Android so I assume it will work with iDevices too. Can build it yourself for around $30.
That sounds interesting. Keep us posted.
beavis
Postby beavis » Sun Apr 19, 2015 10:04 am
I have a Qstarz 10hz connected to an android phone which works fine.
I use RaceChrono2Avi to convert the data to video.
Then, its all put together in your favourite video editing software.
Here's an example, i have many more:
Snowmotion
Postby Snowmotion » Sun Apr 19, 2015 10:27 am
beavis wrote:I have a Qstarz 10hz connected to an android phone which works fine.
I don't believe the Qstarz works with IOS (iPhone).
beavis
Postby beavis » Sun Apr 19, 2015 11:36 pm
Snowmotion wrote:I don't believe the Qstarz works with IOS (iPhone).
I think what you mean is, the iPhone doesn't work with the Qstarz :P
Return to “MX5 Motor Sport”
