reggie wrote:I Gotta say well done - sounds like a great initiative![]()
I have a question please regarding car eligibility. Would a 1994 NA8 Clubman with an aftermarket turbo be eligible for this class of racing? If I am reading and understanding the Modern Sports Car Regs correctly, the answer should be yes?
- The car itself is an eligible model (94 MX5)
- The car's modifications meets CAMS 2B requirements (when paragraph 1.2 is excluded)
- if 1.2 had been included it would fail, as 94 clubman was never factory turbo?
Could you please clarify, have I understood the requirement below correctly?
Thanks in advance for your help with this.
Rod
Vehicles that are on the list of eligible
vehicles need to comply with the current CAMS 2B
or 2F rules as published by CAMS, with the exception of the following
sections which are not relevant:
2F Paragraph 1.2
2B Paragraph 1.2
No. The paragraphs 1.2 relate to the eligibility of certain vehicles. If the vehicle is not on the eligibility list in the appendix, then you can't run. So no a turboed clubman is not eligible. This is to stop the Honda powered loti playing, as there were not 100 made and registered. If you built the car as an SP or SE replica, to the rules, that is standard turbo and inlet and exhaust manifolds then that is eligible if on the list.
For my car I can build a Nizpro 200SX-R for 2B as it is an eligible vehicle on the cams list. For this series, because only 13 in various specs were made it is not eligible so I can only build the car to the standard Nissan spec, that is T25 turbo and standard manifolds.
