wun911 wrote:So when will mazda pump out a NC SP??
Or has the dude that made the SP died??
No Mr Horsely hasn't died
just quickly, what are the prices on an import NC in good condition??
also how much harder/easier are they to get around in terms of removing the factory saftey devices (airbags, pretensioners ect) would you bother with the stability control (I understand alot leave ABS on their race cars)?
is there noticibly more room vertically (for cage/head clearance)?
are their any cooling issues (I hear NA and NB racers complaining often)?
how good is the mazda LSD for the NC, are their any alternatives yet?
how different is the actual seating position?
is it easy to get steering wheel boss's for the NC?
Casey wrote:..... normally aspirated NCs will be disadvantaged compared to the forced induction cars (SP and SE) - the gap at Wakefield last time around was about 4 secs IIRC .
Charlie Brown wrote:Casey wrote:..... normally aspirated NCs will be disadvantaged compared to the forced induction cars (SP and SE) - the gap at Wakefield last time around was about 4 secs IIRC .
***inserts large wooden spoon to stir the mix**********
Results Wakefield 17 Feb:
Turbo Girl (faux SP) 1:09.13
Dave Hammon (SE) 1:11.14
MX5 Racing (NC) 1:11.33
T. Rix (SE) 1:13.43
K. Zudra (SE) 1:13.66
But you are right. The NC will suffer badly around Bathurst as the SPs & SE will be able to pull away up the mountain and then hold up the NCs coming down the hill, before pulling away down Conrod.
I'm not sure if Chris has solved the speed limiter problem with the Jap ECU but I'm sure if there are enough laps then he'll come powering home as the SP/SEs start to overheat.
Casey wrote:There you go again AJ. After the disappointment of the NC's missing the Bathurst 12 Hour race, I opened this thread hoping to read more about the ongoing development of the cars and find that yet again you couldn’t help yourself.
Casey wrote:
Come on Phil - you know no-one has a bigger stirrer then me
orx626 wrote:Charlie Brown wrote:We need something fresh to get everyone churned up.
Ok then............well the NC had to be a massive step up from the NA/NB platform having been derived from the RX-8 platform.
AJ wrote:orx626 wrote:Charlie Brown wrote:We need something fresh to get everyone churned up.
thankfully they left the smoky old rotary where it belonged
