No issue at all with any of the lead acid batteries in there before or after.
Possibly something to do with the NA alternator regulated voltage as opposed to the NB ECU regulated one? and whatever the NC uses (presumably ECU regulated?)
Battery recommendations for a dual use car
Re: Battery recommendations for a dual use car
- davekmoore
The challenge in my car for a lead acid battery is the cornering forces. The acid doesn't want to stay in the battery.
hks_kansei wrote:No issue at all with any of the lead acid batteries in there before or after.
Possibly just a bad battery?
I have had a PC680 in my NA6 for 3.5 years now, still charges fine, starts fine even with high compression.
even if its left for 3 weeks starts first time.
- davekmoore
Ned Loh wrote:beavis wrote:Deka EXT15
that is probably fine. if you want something about the same weight, but with closer to factory spec CCA, you could try one of these (a bit more money though)
http://www.braillebattery.com.au/index. ... ies/b14115
Considered the Braille battery. Then looked at the second post down on this page http://www.miataturbo.net/race-prep-75/ ... 85/page17/
Not considering Braille battery any more.
- Vehicle: Non MX-5
Thes specs on the Deka and Braille seem different, even if they are from the same factory (?). Braille has closer to factory CCA. In reality I think both will do the job just fine.
Users browsing this forum: No registered users and 56 guests
