The in car radio discussion...
taminga16
Re: The in car radio discussion...
Postby taminga16 » Thu May 15, 2014 10:25 pm
How big are the receivers and where do you put them when on the track?
Greg.
toppertee
Postby toppertee » Thu May 15, 2014 10:48 pm
Don't mind, my crappy driving. But if you look at the corner of my seat belt you can just make it out. It's about 60mmx25mmx15mm very small. I just clip in on my race suit (shoulder)and use my I phone ear buds. I can adjust the volume that way as well.
http://youtu.be/t274yCkW5p4
taminga16
Postby taminga16 » Thu May 15, 2014 10:54 pm
Thank you.
Greg.
frog_a_lot
Postby frog_a_lot » Mon May 19, 2014 8:20 pm
Im half half on them..
I did find the ear plugs a little irritating, but it was good to know why the flags where/lights where going.. when you see a red/yellow flag you don't always see what is causing it, so its good to be told about the incident.
david_syd_au
Postby david_syd_au » Tue May 20, 2014 7:25 pm
Does anyone know what frequency they use?
corners
Vehicle: ND - Supercharged
Postby corners » Tue May 20, 2014 7:47 pm
These are the ACMA registrations
http://web.acma.gov.au/pls/radcom/site_ ... _ID=401437
http://web.acma.gov.au/pls/radcom/site_ ... _ID=401729
Other than those it could be Citizen Band UHF
david_syd_au
Postby david_syd_au » Tue May 20, 2014 7:56 pm
corners wrote:These are the ACMA registrations
Thanks "corners".
I also found those on the ACMA site for QR, but curiously, couldn't find anything similar at Wakefield Park.
The first of those records is for a low-power FM broadcast transmitter on 87.6 MHz, so that isn't used for the raceceiver system, so, it must be one of the 400'ish Mhz frequencies in the 2nd record, or not require a license, or ... not be licensed.
Given the importance of the system for track safety, they would not use UHF CB, due to the possibility or interference, deliberate or otherwise.
From pictures I have seen of the raceceiver unit, it appears to show the frequency on the display. Can anyone who has a unit from Wakefield Park tell what the numbers are on the display please?
mazmad
Postby mazmad » Tue May 20, 2014 8:54 pm
They probably change channel from event to event. This is what we used last weekend, cant remember the previous event.
david_syd_au
Postby david_syd_au » Tue May 20, 2014 11:03 pm
mazmad wrote:They probably change channel from event to event. This is what we used last weekend, cant remember the previous event.
Thanks Craig.
That shows channel 601 and 475.5 Mhz, and that lines up with the list here:
http://www.raceceiver.com/Fans/channel-to-frequency/
Interesting that the ACMA site does not show a license for that frequency anywhere near Wakeield. Hopefully that just means that due to power or coverage limits, it doesn't need to be licensed.
Return to “MX5 Motor Sport”
Users browsing this forum: No registered users and 55 guests
