MattR wrote:The problem at the moment is that the tech regs are not available.
I am concerned about references to minimum weights and capacities for FI cars as I am currently building an S14 to 2B rules and a very strict diet is happening to the car as the power is limited by the turbo rules I have to run to.
We also need to know what the basic things are for the cars to actually run, I know that basically 2B and 2F are the basis of the rules, but what tweaks are there going to be. For example if they are going to use restrictors like IPRA, and it clashes with 2B then I need to know now to build the car accordingly, same with engine capacities, in 2B I can run a stroker, but this increases capacity by at least 10% not taking into account going over size in the bores by as much as 3-4mm dpending on how much I want to throw at the motor.
You know there's no trophies for first place in this series?
If your car is to quick, they will more than likely give you a lead trophy, or tell you to, F off instead.
From what I'm to understand this is more about having a good time, I.E. Gentlemen racing not Genital racing
