.....It is 100% more fun being on track with the roof down
deviant wrote:I think one thing that we are all forgetting here is that....
Guran wrote:Lokiel wrote:16bit wrote:only stiffness you will get will be if you have bolted plates instead of the latches.
I disagree. Prior to fitting my roll bar, the chassis felt firmer with the hartop+latches.
http://forum.miata.net/vb/showpost.php? ... stcount=14Like the soft top, the hardtop is an unstressed component. If the hardtop were carrying structural loads, the rear window would pop out of its mountings as the bodystructure flexed by any degree.
The top is able to dampen (slightly) some of the lateral movement of the windscreen header, but the primary reason behind this is that with the top up the visual contrast between header and sky is diminished. With the convertible top raised, the multi-component aspects of the top induce rattles which the single-piece hardtop doesn't have, thereby creating the impression that the hardtop has stiffened the car vis-a-vis the erected convertible top or with the top down.
The car's torsional rigidity was measured in all three planes (as a body-in-white as well as a completed car) with the top down, top up and the hardtop on and there were no appreciable differences in the figures.
I don't question that it may feel stiffer, but this is much more an example of the placebo effect than one actually reducing the bending moment of the car, I'm afraid.
bwob
murph wrote:I know with the top down is a LOT slower
