BIG brake kit for race car
Red 2f MX5
Postby Red 2f MX5 » Wed Jun 25, 2008 4:57 pm
Thinking of putting a bigger brake set up on my 2F NA racecar.
Anybody got any suggestions ?
Anybody had any success with something ?
Brett
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Wed Jun 25, 2008 5:38 pm
from what I hear the dynalite willwood based kits from goodwin racing have a tendancy to flex (CT knows i think). but that said the new version comes with dba5000 seriers rotors which is a big plus and they fit under 15 inch rims
If you go to 949racing.com they are in the middle of developing a big brake kit using the newer dynapro lug mount calliper which is a forged unit and should be much stiffer then the plain billet dynalite caliper. Its a few months off and should be around 1500 usd and can fit under 15 inch rims.
there is an ap racing front only kit but you need 16 inch rims and it costs about the same as the willwood kits which are front and rear.
there is also a brembo kit but you need 17 inch rims.
There is also an endless 6pot front only kit but you need 16 inch rims for those too.
no experience with them but they are the ones I know of.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Thu Jun 26, 2008 1:04 pm
The willwoods work fine on the MX5's...
QR is very hard on brakes so you should think about doing something before you go if you want to upgrade the brakes...
Red 2f MX5
Postby Red 2f MX5 » Thu Jun 26, 2008 1:29 pm
I will put something on before QR if i can.
Nick has offered me his old Wilwood set-up he had on his turbo car. He now has AP on there.
It's front & rear. Calipers, dog bones, discs and hoses for $1500.
I saw on the Goodwin racing site they do kits new for around that type of money.
Will i need to do a peddle box to get the bias right, or just play around with pad compounds.
I thought if i just do fronts it will probably be to much front brake and just lock them up.
Brett
Cal
Postby Cal » Thu Jun 26, 2008 2:47 pm
Red 2f MX5 wrote:I thought if i just do fronts it will probably be to much front brake and just lock them up.
A lot of people up here who have tried Wilwoods and other big brake kits have had the same problem. I really don't think they are necessary. Almost all of us use the standard NA8 brakes.
Red 2f MX5
Postby Red 2f MX5 » Thu Jun 26, 2008 3:29 pm
I have tried acouple of different brake pads.
I found the Hawk blues were real bitey and locked the fronts real easy. I was talking to CT and he said get rid of the booster. I may do that.
I now have EBC yellows in the front and reds in the back. I find that much better, but is the total opposite. You really have to stand on the brakes. And they don't lock up.
I will do some thinking. Probably just run it the way it is for now.
Brett
16bit
Postby 16bit » Thu Jun 26, 2008 3:48 pm
check out the carbotech pads www.ctbrakes.com
I have done a little reading on the miata.net forum and the race guys over there think they are pretty good. They have a pretty comprehensive range of racing compounds and if the talk is correct they are easy on disks and have good pedal modulation. I am going to get some of the xp10 compound for the front for track days. the popular combination is the xp10's on the front and xp8's on the rear. I think in the spec miata class they run stock callipers (not really sure though) so they should be enough.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Thu Jun 26, 2008 9:09 pm
EBC are crap....the Hawk Blues are the best...it's just a matter of getting used to how much pressure you put on the brake pedal...I have no trouble outbraking just about anything.
Red 2f MX5
Postby Red 2f MX5 » Fri Jun 27, 2008 8:40 am
I probably just needed to get used to them. I found you could only use a little bit of pressure otherwise they locked up. i was a bit scared to go in deep in case i just drove off the track or into somebody.
I don't mind the EBC pads. I find they had pretty good feel.
But the hawk blue's had better bite and it probably is just a case of me getting used to something different.
Brett
Red 2f MX5
Postby Red 2f MX5 » Fri Jun 27, 2008 8:41 am
Brett
fish
Postby fish » Fri Jun 27, 2008 3:24 pm
yeah mate as cal said a few have tried bigger brakes with out much success .....they actually induced more lock ups....its just a matter of learning how the hawke blues perform ....i would persevere for now save your money and come up for a lakeside round :mrgreen:
born again 1994 NA8 2F RACE CAR ....No 42
Cal
Postby Cal » Fri Jun 27, 2008 4:01 pm
fish wrote:i would persevere for now save your money and come up for a lakeside round :mrgreen:
:lol: correct
Speaking of which, this 500km relay in September sounds pretty good.
Red 2f MX5
Postby Red 2f MX5 » Fri Jun 27, 2008 4:54 pm
Sounds Good.
I have always wanted to race at Lakeside.
I am in Fiji mid September but if it's not while i am away i will come up for sure.
Brett
Return to “MX5 Motor Sport”
Users browsing this forum: No registered users and 278 guests
