Best 3 Bar MAP sensor for NC?
Jalb_k
Postby Jalb_k » Sun May 19, 2019 6:52 pm
As the subject asks, what options are out there?
Preferably a plug and play option but I'm not averse to OEM plug replacement. My tuner thinks my rotrex setup is making more boost than the stock MAP can handle and the car is just not happy over 4k rpm.
Any help appreciated.
Sent from my Pixel XL using Tapatalk
16bit
Vehicle: NB8A - Supercharged
Re: Best 3 Bar MAP sensor for NC?
Postby 16bit » Sun May 19, 2019 9:06 pm
any more info on how the car is being tuned? what ecu are you using? is it stock ecu being reflashed?
i would maybe ask the tuner to recommend one.
also this is probably a subject for either the forced induction or electronics sub forums.
Jalb_k
Postby Jalb_k » Sun May 19, 2019 9:21 pm
16bit wrote:any more info on how the car is being tuned? what ecu are you using? is it stock ecu being reflashed?
Reflashed stock ECU. I send logs and flash ROM gets sent back.
16bit wrote:i would maybe ask the tuner to recommend one.
They have one on their site but was hoping someone would have an Australian site or dealer recommendation.
16bit wrote:also this is probably a subject for either the forced induction or electronics sub forums.
You are probably right, I should have gone to the FI board. Admin, feel free to relocate.
16bit
Postby 16bit » Mon May 20, 2019 12:41 pm
maybe try out ecutek, deckspeed or even chiptorque.
they may have something.
