Page 1 of 3
How you get a charge
Posted: Tue Sep 25, 2018 10:57 pm
by Rocky
As I mentioned in the "Shitz" thread, my hardly-used Trickle-Charger no longer works. Looks like I need a new one.
It will be used as a "Trickle-charger" to maintain the NB's 8 yo OE Panasonic battery.
Crystal normally gets a 100k open-road run every week but a couple of times a year we go on hols for a few weeks and I am not confident that an 8 yo battery will handle sitting at home in the garage for that amount of time without it's regular run.
I have had a bit of a search on here and a Charger that gets a recommendation is the "CTEK XSO.8" which I find is available on eBay for $84.50
(I want the permanent battery terminal connections that come with this particular item as it allows easy safe connection to power.)
It is described as a charger for charging "smaller 12V batteries found in MCs, JetSkis, ATVs and lawnmowers." It also says :
"also suitable for maintenance charging “normal- sized” batteries such as car batteries."
I am not interested in anything costing more than $100. as this is only going to get used occasionally.
Anyone have any suggestions as to better Trickle-Chargers that can be purchased on eBay OR through REPCO, Supacheap or Autobarn.
Re: How you get a charge
Posted: Tue Sep 25, 2018 11:21 pm
by Okibi
I have the Ctek MXS 5, does a good job
I also have one of these i've been too lazy to install
https://www.ctek.com/products/vehicle/i ... panel-1-5m
Posted: Tue Sep 25, 2018 11:26 pm
by manga_blue
Just get a C-TEK you won't regret it. I had a Haigh before my C-TEK. It refused to acknowledge any battery that was less than 20% full and eventually fused. I was very lucky not to lose the shed and two cars.
Posted: Wed Sep 26, 2018 8:01 am
by rascal
+1 for C-Tek. I also have a 5.0 one for the track cars tiny agm, but the 0.8ones would be just as good for top up usage.
I’m actually thinking about getting another one for mower, trailer use in the winter months where they’re not used much.
Posted: Wed Sep 26, 2018 9:41 am
by charcoal
another +1 for C -Tek
When we replaced the original equipment battery on our NB around 3 years ago, the RACQ Batteries technician recommended C- Tek for Gel battery charging. Autobarn had a special offer which was too good to miss - MXS 7.0 for less than $100. It has proved to be exactly what we need when recharging is required for our "stable" and is simple to use.
Our car gets significantly less use than yours and only sees the light of day on MX5CQ runs. That said, we have another solution to the discharging problem that is common. We have one of the battery disconnection devices attached to the terminal and find that the car always has sufficient charge to enable an easy start every time we need it. The only "negative" (pun intended) to this arrangement is that the trip meter readings are lost and need to re-set the radio station buttons...no biggies.
Over the years, various inexpensive old style battery chargers and a couple of trickle chargers have been tried and can't really be recommended.
Posted: Wed Sep 26, 2018 10:25 am
by Rocky
Thanks Guys, that makes it easy. I have ordered the CTEK.
Manga, your comment about the Charger that fused caught my attention. Being a bit of a "worry-wort" by nature I must admit to wondering if I really want the MX5 connected to the Trickle-charger while I am away for a few weeks. So there actually IS some risk involved with these devices?
Posted: Wed Sep 26, 2018 11:00 am
by hks_kansei
Personally I'd never leave a battery charger unattended, far too much risk of a short/fire.
If i were going on a long distance trip I'd just remove the battery and sit it in the shed somewhere (no chance of current draw), then just use a normal charger when I got home (if it needed a topup)
No fire risk, and also the benefit of making the car harder to steal should somebody break into the house while i'm away.
(granted, if I'm going away I tend to also remove a few other bits from the car so it wont start, battery or not)
Posted: Wed Sep 26, 2018 11:29 am
by 93_Clubman
^+1
Posted: Wed Sep 26, 2018 4:20 pm
by Rocky
OK - that sounds like a plan. I'll be able to sleep soundly on hols knowing my car & house aren't burning down.
The sales spiel says:
"The CTEK XS 0.8 battery charger is IP 65 classified (splash and dust proof), delivers 0.8A and is designed to protect vehicle electronics. It is non-sparking, reverse polarity protected and short-circuit proof. "
Whether this means anything I wouldn't know.
Posted: Wed Sep 26, 2018 4:27 pm
by Mr Morlock
An expensive charger (Ctek) I have 2 trickle chargers and never had a problem with them and used regularly. I would not leave my NB for more than 2 weeks without a trickle on it.
Posted: Wed Sep 26, 2018 4:32 pm
by hks_kansei
All good stuff, and sound like good useful safety features.
But I'd still just prefer to charge it once I got home, safety things are like insurance, you buy them in the hope that you've wasted your money.
worth noting, my battery charger is an old scabby Arlec thing with literally 3 lights on it and nothing more (flat-charging-charged) so i'm probably swayed towards being more risk averse since it doesn't have any safety features at all.
Posted: Wed Sep 26, 2018 4:55 pm
by JBT
hks_kansei wrote:Personally I'd never leave a battery charger unattended, far too much risk of a short/fire.
Posted: Wed Sep 26, 2018 8:05 pm
by project.r.racing
I have a big 5amp ctek. No issues. Pretty sure I brought it through ebay.
But - why spend $100 on a charger to maintain a 8yo $100 battery?
Posted: Wed Sep 26, 2018 8:36 pm
by JBT
Posted: Wed Sep 26, 2018 9:23 pm
by Rocky
Well of course it's the OE Panasonic - the last one cost $420. in 2010.
I retired the previous one before it failed at 9 years and I'd like to get at least another year out of this one.
Driving only once a week with a 2 - 3 week holiday a couple of times a year, I figure any battery, old or new should benefit from a Trickle-charge now and then.
