ND aerial change?
d4m0
ND aerial change?
Postby d4m0 » Mon May 28, 2018 8:56 am
I'm not a big fan of that whippet type aerial on the back of the NDs - what are the alternatives without losing some kind of radio goodness? Anyone have any ideas, or have done something similar (changed it for something less chintzy)?
MikeVictor
Re: ND aerial change?
Postby MikeVictor » Mon May 28, 2018 7:20 pm
Hi mate.
You've got two problems here. Changing your aerial for a stubby one will likely reduce its efficacy. Second, a lot of the ones for sale I've seen don't look that great even if they do have a close to flush fitment.
Both of these aspects give you chintz, which you are trying to avoid. Nothing wrong with the stock antenna IMO.
ND GT with a loose nut behind wheel
d4m0
Postby d4m0 » Thu May 31, 2018 8:32 am
Yeah, it's a bit of a puzzle. Mazda says the "sharkfin" antenna is the new wave (http://www.mazda.com/en/innovation/mazda-stories/engineers/shark-fin/) and has all the bits you need - the ND has both a sharkfin (on the boot) and the 90s throwback whip antenna. Presumably the whip is for AM/FM (what is that anyway?), and the sharkfin for the GPS and DAB stuff. I'd rather delete the whole whip, but could settle for stubbing it.
apsilon
Postby apsilon » Thu May 31, 2018 9:11 am
Assuming the antenna just unscrews from the base you could try one from I believe a Mazda 3, part EG23-66-A30. Under $30 IIRC. I don't know for certain that the thread will match but I think there's a fair chance.
My Ranger had a long whip antenna mounted on the roof. Fortunately on a hinge so it could be folded down almost flat but looked a bit silly and was still a risk of being caught on something in a car park etc as well as interfering with the roof rack I plan to fit. I changed it for the Mazda one above. Perfect fit and I've noticed no change in reception.
'97 Neo Green limited edition
OMY005
Postby OMY005 » Thu May 31, 2018 9:56 am
I replaced mine with one of these, radio works ok still. :D
https://www.mx5parts.co.uk/short-rubber-aerial-mk4-p-3791.html?currency=AUD
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
MikeVictor
Postby MikeVictor » Fri Jun 08, 2018 9:25 pm
d4m0 wrote:Yeah, it's a bit of a puzzle. Mazda says the "sharkfin" antenna is the new wave (http://www.mazda.com/en/innovation/mazda-stories/engineers/shark-fin/) and has all the bits you need - the ND has both a sharkfin (on the boot) and the 90s throwback whip antenna. Presumably the whip is for AM/FM (what is that anyway?), and the sharkfin for the GPS and DAB stuff. I'd rather delete the whole whip, but could settle for stubbing it.
ND has the sharkfin in Australia? You sure about that? Mine certainly doesn't and I don't recall seeing one ever with it.
IMO I'm glad it doesn't too, looks odd and out of place on the boot on pics I've seen of US models, which AFAIK have it for satellite radio.
d4m0
Postby d4m0 » Fri Jun 22, 2018 8:18 am
MikeVictor wrote:ND has the sharkfin in Australia? You sure about that? Mine certainly doesn't and I don't recall seeing one ever with it.
Aww hell, I don't know. I look at so many pictures it's hard to tell where I saw what.
