differences I believe are
* Leather interior + nardi wheel
* LSD
* No power steering (manual rack)
* 'bigger' brakes
* some body stiffening?
* more weight?
matt.
StanTheMan wrote:why would you have a NA6 whaen you have a Clubman?
NA6 owners try to pretend that they are NA8.....upgrade every NA6 part to a NA8 part....
I should know...Ive almost completed the full Journey.
essentially....the Clubman is the closest relative the NA6 has. Except the Clubman has all the good bits on it that the NA6 really needs. or should have had in the first place.
StanTheMan wrote:why would you have a NA6 when you have a Clubman?
shirtz wrote:well mine was 4k with a hardtop no rego. 177k but a good crank wobble, hail damage. has a bunch of parts too.
Lokiel wrote:I'm wondering if it would be financially better in the long run to bring the NA6 back to spec, sell it, then buy the NA8 you're trying to turn your NA6 into (preferably buy an NA8 that's a little "tired" so you can get it cheap).
Faithfully restored NA6s are probably the only MX5s that will ever earn "Classic Car" status.
