Mx5 boot leak
Mx5 boot leak
Hi people first time poster, just bought a NB MX5 in green about 2 weeks ago, love the car but it hasn’t been without it promblems.
Air con regas $150.00
New boot rubber $50
Cam angle sensor and replace clutch slave cylinder and repair puncture to front tyre $400
Replace left soft top latch with used $90
Left hand door lock fell inside door will try and fix tomorrow with a mate
Car purchase $5300 with 12 months rego
Boot still leaking carpet damp around the centre and upper right
Doesn’t anyone know were it might be coming from?
Any help will be appreciated
Thanks Michael
New boot rubber $50
Thanks Michael
Re: Mx5 boot leak
Check the tail lights rubber seal/gasket.
6' 7" red tardis owner (spacious 89 NA8 clone) and cleaned up 92HZ SBY.
- Regie
- Vehicle: NC - V8
Re: Mx5 boot leak
also the rubber seal around the middle brake light
Re: Mx5 boot leak
Tail lights
rain rail
or even the hardtop chrome brackets with the 2 bolts ontop of them can leak
Aerial / antenna down tight sealing good also ?
rain rail
- JBT
Re: Mx5 boot leak
redchicken wrote:Boot still leaking carpet damp around the centre and upper right
Soft top rain rail leaking
Re: Mx5 boot leak
Thanks for the replies guys
How do I go about checking the rain rails?
- JBT
Re: Mx5 boot leak
You will have to remove the rear trim behind the seats and check the rain rail for leaks. https://www.youtube.com/watch?v=V7RWEpFuo0M
Re: Mx5 boot leak
Thanks mate
- JBT
Re: Mx5 boot leak
Clean out all the drains, as water leaking into an MX5 is often due to blocked drains: viewtopic.php?f=28&t=35601
- bruce
- Vehicle: NA8 - Turbo
Re: Mx5 boot leak
Yup, I'd second the drains. Keep your face clear as it is usually a flood of water when clearing them.
Re: Mx5 boot leak
Thanks for the replies guys I have cleaned out the drain holes behind the seats they were seriously blocked you should have. Seen the stuff that came out. The boot is still leaking with the water pooling around the battery on the drivers side and in the spot on the passenger side. Any ideas guys. My car is parked outside on incline with bonnet up toward the top of the incline and the boot on the downside of the incline. Could this be contributing to the water pooling in the boot?. Thanks Michael.
- JBT
Re: Mx5 boot leak
If you have completely cleared the rain rail drains you could have cracks in the rail itself. You will have to get to the rail (it is where the roof attaches at the rear of the cabin/cockpit) and check it. Race tape will work to seal up any cracks until you can source a replacement rail.
Double check that the boot seal is fitted correctly.
Did you check this?
Did you check this?
Is any water getting into the cabin/floor area?even the hardtop chrome brackets with the 2 bolts on top of them can leak
Re: Mx5 boot leak
redchicken wrote:My car is parked outside on incline with bonnet up toward the top of the incline and the boot on the downside of the incline. Could this be contributing to the water pooling in the boot?
Yes
- JBT
Re: Mx5 boot leak
If the drains and rail are properly cleaned, it would need to be a fairly severe incline for water to get into the boot.
