Shop in Brisbane that can look at a megasquirt
Hugo999
Vehicle: NC - Turbo
Postby Hugo999 » Tue Sep 26, 2017 10:38 pm
Hello,
I have been struggling with a ignition problem where I have only one coil firing on my 91 mx5. I have been through basically every ignition part I can think of and the car is still misfiring. This leads me to think it can only be the ecu causing this. Does anyone know of a shop or someone that can diagnose a faulty ignition circuit in a megasquirt DIYPNP in the Brisbane area?
Thanks, Hugo.
Re: Shop in Brisbane that can look at a megasquirt
Postby NitroDann » Tue Sep 26, 2017 11:17 pm
It's probably the ECU this is why I don't touch hand built ones anymore
Hugo999
Vehicle: NC - Turbo
Postby Hugo999 » Tue Sep 26, 2017 11:30 pm
Have put new plugs, leads, ignitor on the car. Tested coilpacks and CAS and proved both working. Wiring checks out on continuity. Can only be the ecu then I think?
Have this all detailed on another forum but not sure if I am allowed to post it here. Also have datalog but I'm not skilled enough to read it myself (https://goo.gl/rW4DtL).
Going insane trying to diagnose this and hoping someone in Brisbane knows what they are doing with a megasquirt and can have a look at it.
tang0_au
Postby tang0_au » Fri Sep 29, 2017 12:29 pm
similar question - would like a shop to dyno tune my plug n play ... everything works, just needs a final tune ...
Postby Magpie » Fri Sep 29, 2017 2:10 pm
wasp47
Postby wasp47 » Fri Sep 29, 2017 8:15 pm
I realise its not Brisbane but CHIPTORQUE at Nerang should be able to assist, They are within easy walking distance from the station should you need to leave your 5 there . Lachlan Is the man to talk to.
Steven
