Solid engine mounts ?
ninerwfo
Vehicle: NB8A - Turbo
Postby ninerwfo » Fri Sep 15, 2017 7:41 am
Hi folks, is there anyone in Brissie or Gold Coast running those AWR engine mounts, who'd let me peek under the bonnet?
Seriously considering making my own (different) design, and would love to know about plate thickness, etc???ImageImage
StanTheMan
Re: Solid engine mounts ?
Postby StanTheMan » Fri Sep 15, 2017 8:19 am
I'd also love to know how different they feel. I would assume a bit more vibration? also does it contribute to less driveling loss? If it does I would assume it only translates a small amount?
Postby Mr Morlock » Fri Sep 15, 2017 11:37 am
I guess its for a race car- something rarily used on the road. Why would you substitute a properly engineered engine mount for a plastic bush? It will add a lot of NVH - an engine mount isolates a lot of vibration which really makes motoring hard work. Vibration breaks things as well- including the spirit. The car industry worked hard to actually make cars more amenable to being driven- and a good rubber mount is part of that.
Postby NitroDann » Fri Sep 15, 2017 12:52 pm
If you install a pair the car will vibrate a lot if you install only one it's pretty livable in a daily Drive but it's nothing like a standard Mercedes people replace them because the factory ones tear very regularly when the car is dríven hard especially when it makes good power.
chops
Postby chops » Fri Sep 15, 2017 1:24 pm
what Dann said
I have a set I would sell cheap
wasp47
Postby wasp47 » Fri Sep 15, 2017 3:25 pm
I believe the SE mounts are firmer
wasp47
Postby wasp47 » Fri Sep 15, 2017 3:27 pm
Mark , who owns The Car Clinic at Southport has a set, or similar, on his Supercharged NA
davekmoore
Postby davekmoore » Sat Sep 16, 2017 2:47 am
StanTheMan wrote:I'd also love to know how different they feel. I would assume a bit more vibration? also does it contribute to less driveling loss? If it does I would assume it only translates a small amount?
Whole car has low level vibration at idle. Reduce gearshifter movement by a useful amount, thus improving shifter feel at the expense of having to use Loctite on the shifter bolts because of the vibration.
Mine have the 90 durometer bushings and I did 50,000klms in it on country Vic roads in a year with no complaints.
3gress
Postby 3gress » Sat Sep 16, 2017 6:01 am
A quick measurement found plate thickness on the AWR mounts to be 4mm.
Perhaps the hybrid mounts stocked by 949racing would be a good compromise if the car sees the street often?
The hybrid mount package provides one driver's side AWR mount identical to those in OP's pic, the passenger side mount is a Mazdaspeed Motorsport mount with a higher durometer.
Haven't had the chance to evaluate NVH but am expecting a livable compromise between cabin comfort and shifting improvement.
3gress
Postby 3gress » Sat Sep 16, 2017 7:23 am
Supermiata. The hybrid kit is made by Supermiata not AWR as stated.
..and 'Mazda Comp' P.S. rubber mount.
Apologies..
