Na8 weight
mossy
Na8 weight
Postby mossy » Thu Feb 23, 2017 8:35 pm
How can I find out the weight of an Na8 fully loaded, has to be accurate for VASS, would Mazda head office email details?
Alex 2550
Re: Na8 weight
Postby Alex 2550 » Thu Feb 23, 2017 8:52 pm
Put mine on weigh bridge it was 1035kg with hardtop and half a tank of fuel.
I then took 17kg of crap out of the car that I didn't need.
Sorry not sure my hardtop weight as they vary I would say around 15kg perhaps, it's very easy to lift off with one person and is demister type.
Re: Na8 weight
Postby hks_kansei » Thu Feb 23, 2017 9:10 pm
Weighbridge, they can usually provide a certificate from memory.
Or just head to your local dump, they usually have a weighbridge at the entrance and exit to know how much sh*t you've dumped and to charge a accordingly.
Re: Na8 weight
Postby NitroDann » Thu Feb 23, 2017 10:58 pm
Many mechanic garages have the platetronic brake testing maching which also has calibrated scales good for the RMS/RTA/Vicroads/whatever.
Re: Na8 weight
Postby Mr Morlock » Fri Feb 24, 2017 10:41 am
You would need to get your terms correct as far as weight is concerned - GVM GCW etc. What does fully loaded mean? I would say that Mazda state some specific weights for all their vehicles.
Re: Na8 weight
Postby 93_Clubman » Fri Feb 24, 2017 11:21 am
FWIW, kerb weight of NA8 is 990kg - kerb weight = https://en.wikipedia.org/wiki/Curb_weight
Re: Na8 weight
Postby bruce » Fri Feb 24, 2017 11:52 am
Ask your engineer which weighbridge he prefers. Ask if he wants a front/rear split. Only cost $17.50. Be prepared to sit amongst some massive trucks.
mossy
Re: Na8 weight
Postby mossy » Fri Feb 24, 2017 2:33 pm
Mr Morlock wrote:You would need to get your terms correct as far as weight is concerned - GVM GCW etc. What does fully loaded mean? I would say that Mazda state some specific weights for all their vehicles.
When I said loaded I just meant the heaviest that series of car would have been, with all options such as A/C and hardtop.
Needs to be over the 1000kg mark to get the engine conversion done, NB would be the easier way but I've always had NA's, I prefer the look and I'd like to use club permit as well which wouldn't be possible with the NB. Weighbridge might be the answer then, cheers
Re: Na8 weight
Postby manga_blue » Fri Feb 24, 2017 2:56 pm
G'day Mossy - long time.
My NA8 was 1033Kg over the Eastern Creek weighbridge. That was with BD rollbar, full standard interior, A/C. P/S, soft top (which I think I bought from you about 10 years ago :D ), 1/3 tank of fuel.
mossy
Re: Na8 weight
Postby mossy » Fri Feb 24, 2017 8:34 pm
manga_blue wrote:G'day Mossy - long time.
Definetely a long time mate, over 10 years I reckon. Sounds like it should be over 1000kgs, a hardtop will add at least 20kg's too.
Re: Na8 weight
Postby manga_blue » Fri Feb 24, 2017 10:45 pm
Nevertheless my old VicRoads rego papers say its 950Kg. It's never been weighed. Maybe they just go off whatever they have in their database.
S2-13BT
Re: Na8 weight
Postby S2-13BT » Fri Feb 24, 2017 11:34 pm
I had my stock '95 on a weigh bridge about a week ago. 1080kg with me in it (90kg), and 4/5ths fuel.
Re: Na8 weight
Postby 93_Clubman » Fri Feb 24, 2017 11:55 pm
manga_blue wrote:my old VicRoads rego papers say its 950Kg.
Interesting, mine says 990kg & Vicroads also haven't weighed it.
Re: Na8 weight
Postby Mr Morlock » Sat Feb 25, 2017 12:55 pm
I am still not sure - not that it matters- why the car need " needs to be over the 1000kg mark to get the engine conversion done" If the vehicles is planned for CP in Victoria the engine conversion would need to at least be checked as well as the car might have to have an M plate or a VASS etc. You will not be able to change an engine without it being legal and noted- the RWC checker lists the eng nbr and if it does not agree with prev reg etc it will flag up.
As far as descriptions on cars by Vicroads are concerned details are often hit and miss. As far as weight is concerned if this was required to be stated you could pretty put in what you think is correct.. CP log book and data don't list the weight of the vehicle as a reference.
mossy
Re: Na8 weight
Postby mossy » Sat Feb 25, 2017 1:10 pm
I should point out the reason I need it to be over 1000kgs is I want to do a 1UZ conversion which is a 4lt v8, the max I can fit in is car weight x 4.
Club permit would be preferred as it would get dríven probably once a week, my 240z is on a 45 day a year permit and i don't even reach that amount.
