NitroDann alloy washer bottle pics and review
Alex 2550
Postby Alex 2550 » Wed Jan 04, 2017 9:34 pm
Hey everyone,
happy new year, i hope the festive season was good for you and your families.
i thought i would put up some pics and a review of the NitroDann alloy washer bottle i purchased in the group buy last year and finally got around to fitting it last night to my NA8.
the Alloy washer bottle sits in the cowl in front of the windscreen on the drivers side.
the reason i purchased the alloy tank was because when i did the cowl intake i obviously had to relocate the washer bottle which i had attached to a temporary metal bracket in the engine bay. the plan was to get a Suzuki washer bottle as used in the NOPRO kit but as i am building a bit of retro/JDM themed roadster the alloy really appealed to me and looks much nicer than a clear piece of plastic. Also because i was going to just get the Suzuki bottle i would need to make brackets ect and Danns solution bolts straight up. Even if you don't have a cowl intake this gives a nice touch and cleans up the engine bay.
Dann sends you a plug and play wiring harness extension, a nice chrome with rubber seal lid, the alloy washer bottle of course and a NitroDann sticker!!! (plus 5rwhp right there!!!) :D
the first thing i noticed when opening the parcel was the quality of the welds, i wish i could tig weld like Dann.
There is certainly no lack of pride in the workmanship and i know it has been said before but Dann's work is superb and commendable especially considering these are a fairly low cost item. Well done Dann.
you need to remove the washer pump motor from your factory tank and the rubber seal and fit it to the alloy tank, it all went straight in and no leaks.
i then did a trial fit to see where everything lines up and can happily say everything lines up perfectly. one end of the tank has a bracket with a hole in it the other mounting point is a threaded insert welded to the tank.
the threaded end lines up with a hole in the fire wall that had a grommet in it that i removed, the other end lined up with a bolt that holds one of the air con line brackets.
the rubber grommet i removed i reused in one of the many factory holes on the frame rails.
for the threaded end i used a bolt, washer and spring washer. the other end with the bracket i used a longer bolt with a washer and a Nylock nut to hold everything tight.
i gave the tank a quick hand polish while out and machine polished the bolt heads for a nice little touch. dirty old bolts wouldn't look right with the shiny new tank.
one concern i had with Danns solution was the tank rubbing inside the cowl causing rattles, rubbing through the paint and rust starting. Dann was way ahead of me and the tank has thick adhesive foam to prevent this which for me showed that thought went into this and once firmly mounted the only movement in the tank is cowl flex.
i had to extend my washer lines so i got all brand new lines to replace all the old dirty ones. (not fitted yet)
i think it looks really good in the engine bay and with the bonnet closed you can get a small shiny glimpse of one of the welded edges through the bonnet gap, sought of hinting that something is going on under the bonnet.
so in short
Value- 5 stars.
build quality- 5 stars.
fitment- 5 stars.
looks- 5 star.
i highly recommend this part and no i dont get any kickbacks or have any financial interest in Danns business, just letting you guys know my experiences of this quality item.
i will put photos up under this post, one is by NitroDann showing the tanks. the other photos are mine and aren't the best as the car hasn't had a good detail and been sitting collecting dust a bit lately but also i don't want to show my engine bay till i update my build thread 8) once i do that i will get some decent photos for you all. :D
cheers
Alex
Alex 2550
Re: NitroDann alloy washer bottle pics and review
Postby Alex 2550 » Wed Jan 04, 2017 9:40 pm
Ruffian147
Postby Ruffian147 » Wed Jan 04, 2017 10:06 pm
How much are these?
Alex 2550
Postby Alex 2550 » Wed Jan 04, 2017 10:10 pm
Pm NitroDann but I believe $175
taminga16
Postby taminga16 » Wed Jan 04, 2017 10:14 pm
Lovely.
Greg.
Postby Okibi » Wed Jan 04, 2017 11:29 pm
I put a few install pics on DriveTribe but it was so quick and easy to do I didn't take enough of the entire process.
LiteIsRite
Postby LiteIsRite » Thu Jan 05, 2017 8:31 am
Great write up, Alex, thanks. Where did you buy the replacement tubing?
"Cherry" - Classic Red 1990 NA6 :NA6: [sold]
Snowmotion
Postby Snowmotion » Thu Jan 05, 2017 9:16 am
Great write up.
You can also reverse the tubing for the washers under the bonnet and use what you have. I actually removed one section of hose (about 20cm) to make it the right length.
Alex 2550
Postby Alex 2550 » Thu Jan 05, 2017 9:41 am
LiteIsRite wrote:Great write up, Alex, thanks. Where did you buy the replacement tubing?
i got mine from my local autopro however i think most places would stock it, i have used clear fuel hose before off motorbikes/lawn mowers because i had it laying around.
Snowmotion wrote:Great write up.
thanks mate, im putting the new stuff on tonight and will look at doing what you have done, makes sense and would mean the water is being pumped as far. thanks for the tip.
Okibi wrote:I put a few install pics on DriveTribe but it was so quick and easy to do I didn't take enough of the entire process.
yer its extremely easy and anyone can do it, i more talked about the intall to give some depth or it would of just said "you need dis" lol :D
Postby NitroDann » Thu Jan 05, 2017 2:04 pm
Thankyou for the kind words.
They are in stock, 175aud delivered within Australia. These come with the tank, the lid, and the wiring harness extension. Everything else is reused from OEM parts including the hoses, which are flipped 180* on the bonnet and then its a direct fit.
