I came across this recent/current list of E85 outlets in Queensland; any other state lists available?
QLD
***Northside***
- United Virginia (1780 Sandgate Rd, Virginia)
- United Bald Hills (73 Strathpine Rd, BALD HILLS)
- United Noosa (686 Eumundi Noosa Rd)
***Southside***
- United Loganlea (254 Loganlea Road, LOGANLEA)
- United Arundel (1 Marble Arch Place ARUNDEL)
- United Crestmead (169-175 Bumstead Road, CRESTMEAD)
- United Forestdale (466-486 Johnson Rd, FORESTDALE)
***West***
- United Toowoomba (172 West Street, (Cnr Stephen Street), TOOWOOMBA)
- United Dalby (37 Drayton Street (Cnr Condamine Street), DALBY)
- United Warwick (31 Helene Street, WARWICK)
***Far North QLD*** (Outside 'Brisbane')
- United Bundaberg (Cnr Walker & 54 Boundary Streets, BUNDABERG SOUTH)
- United Rockhampton (316 Lower Dawson Road, ROCKHAMPTON)
- United Gladstone (13 French Street, Gladstone)
United Hervey Bay (53-83 Maryborough-Hervey Bay Road, HERVEY BAY)
- United Mackay (139 Sydney St, Mackay QLD 4740 )
NSW
**Northern NSW***
- United Tweed Heads (6 MINJUNGBAL DRIVE, TWEED HEADS SOUTH)
State wide E85 locations
- Daffy
Re: State wide E85 locations
That is a very old list....
Use the United and Caltex app to find E85/Flex Fuel. If you want race E85 then that is also easy to find.
Are you able to run E85 and 98? If so then my biggest issue was finding a regular supply of 98 especially in central QLD.
- Daffy
I'll download those apps for sure. I can run both or a mix of both- Interesting that, the lack of 98 in central QLD.
I have up to 7 x 20ltr jerry cans at home full with E85. Found out about the lack of 98 when I went for a drive up to Blackwater and the surrounding areas. You can keep some octane booster with you if using 95, but only use if desperate and no 98 available,
- NitroDann
The last flex fuel car I did made well well over 200rwkw on a very soft 'valet tune' on 98, and could easily be run on regular cat piss 95. I urge everyone with a flex fuel setup to make this choice.
- Daffy
NitroDann wrote:The last flex fuel car I did made well well over 200rwkw on a very soft 'valet tune' on 98, and could easily be run on regular cat piss 95. I urge everyone with a flex fuel setup to make this choice.
I'm currently have Jim Berry (Race Clutch) putting a new clutch together for me, as well as tidying up with some new gauges over the next couple of weeks- I'll be looking at the tune again straight after (seems a couple of minor voltage issues with idle when the lights and a/c are running) but will touch base with you prior Dann RE being able to run 95 if ok.
