Any ND owners use the proximity lock feature?
Blade_Hunter
Postby Blade_Hunter » Tue Jun 21, 2016 2:42 pm
I have a small issue, I use the Proximity lock which is a great feature but when I get out to fill the car up with fuel, it locks just as I get to the petrol cap.
Because the petrol cap is a push open style, it locks also. Then I have to piss about with getting the key out of my pocket and unlocking the car before I can open the cap and fill up.
I asked Mazda and they said the delay or distance cannot be changed.
I find this most strange as my wife's CX5 has the same feature and you need to be about 4 metres from her car before it locks, mine locks when I get to the cars bum.
Anyone experience similar issues? Is mine faulty and it should be similar to the CX5?
davekmoore
Re: Any ND owners use the proximity lock feature?
Postby davekmoore » Wed Jun 22, 2016 12:54 am
PM me tomorrow to remind me to check other NDs.
Postby Okibi » Wed Jun 22, 2016 1:06 am
Perhaps too much testing in the US market where the "gas cap" is on the same side as the driver, and not enough long drive testing in Japan? Hope Dave and find you a solution, it's awesome having a dealer who's also an enthusiast.
Blade_Hunter
Postby Blade_Hunter » Wed Jun 22, 2016 9:18 am
PM Sent, thank you so much for your help :).
note: I do have to say though, filling up is a rarity, completely different to my Liberty GT which used 16.8 L/100 ;)
beavis
Postby beavis » Wed Jun 22, 2016 10:16 am
off topic, but we're getting 7.5l/100km in the 2.0l.
needs less economy and more fast.
Roadrunner
coyotes after you
Postby Roadrunner » Wed Jun 22, 2016 10:55 am
Slightly off topic, Is the proximity lock on all NDs?
Our GT has the keyless start and a button on the door handle to lock / unlock and we've never noticed the car lock itself when walking away?
MeepMeep
Blade_Hunter
Postby Blade_Hunter » Wed Jun 22, 2016 11:00 am
beavis wrote:off topic, but we're getting 7.5l/100km in the 2.0l.
Mine sits around 8.2 as my drive to work is 7 k's of suburbia but coming home from Newcastle the other day it said 5 point something :).
Roadrunner wrote:Slightly off topic, Is the proximity lock on all NDs?
In the infotainment settings, you will find the walk away lock feature, it's turned off by default. Turn it on and it locks itself when you walk away from the car if all doors are closed and engine is off (and in park if an auto)
Do any of you guys use the fuel economy app? I have mine set to show me a summary when I turn the car off, it's quite interesting :).
Need more apps, maybe an animated speedo and tacho ;)
oppolock
Postby oppolock » Wed Jun 22, 2016 12:26 pm
I don't use the proximity lock feature as I would get too stressed that it didn't lock when it walked away. A guy on the UK mx5 club forum was so annoyed about the petrol cap issue he made a video about it
https://www.mx5oc.co.uk/forum/yaf_posts ... eview.aspx
ND 2.0 GT, Eibach springs, GWR Q muffler, Enkei TS10 17x8, Michelin PS4 215/45
Blade_Hunter
Postby Blade_Hunter » Wed Jun 22, 2016 1:23 pm
The link broke when you pasted it.
https://www.youtube.com/watch?v=21idHU5nYq8
That is hilarious :)
project.r.racing
Postby project.r.racing » Wed Jun 22, 2016 1:58 pm
Mazda will add 50g to a newer version and have a sensor on each side of the car.
davekmoore
Postby davekmoore » Wed Jun 22, 2016 2:32 pm
In MZD go to Settings/?Vehicle/Door lock and change it from 30s to 90s. That should give you enough time to get to the filler cap. Mind you, 30s should be enough too. Maybe also look on the same screen for if auto lock is enabled and consider disabling it.
davekmoore
Postby davekmoore » Wed Jun 22, 2016 2:34 pm
Only Roadster GTs have it.
Roadsters do not have it.
Lock on walk away needs to be enabled, if you want it, on the MZD screen in Settings/Vehicle/Door lock.
Blade_Hunter
Postby Blade_Hunter » Wed Jun 22, 2016 2:57 pm
davekmoore wrote:In MZD go to Settings/?Vehicle/Door lock and change it from 30s to 90s. That should give you enough time to get to the filler cap. Mind you, 30s should be enough too. Maybe also look on the same screen for if auto lock is enabled and consider disabling it.
That time is only for the auto RElock ie if you unlock the door then don't open it, it will relock in that many seconds.
davekmoore
Postby davekmoore » Thu Jun 23, 2016 9:22 am
Blade_Hunter wrote:I have a small issue, I use the Proximity lock which is a great feature but when I get out to fill the car up with fuel, it locks just as I get to the petrol cap.
Perhaps your ND has auto lock turned on and the CX-5 doesn't?
Users browsing this forum: madmort and 3 guests
