nb8b coolant reroute???
So, iv heard a few different things from a few different people, and what i wanna know is, Is a coolant reroute a good idea or a bad idea?
people have told me that they redesigned the flow for the head so that it doesn't have cylinder 4 cooling issues, i just wanna see if this is right or wrong,
and if i should just do the reroute on me new motor?
- NitroDann
Re: nb8b coolant reroute???
Short answer is, "Yes do it."
Long answer is, "Do you really want the long answer?"
NitroDann wrote:Short answer is, "Yes do it."
okay, well just checking, cause i was going to leave the thing stock but it the cooling issue is still an issue,
gotta get rid of that issue.
- NitroDann
I dont really understand what you just posted, to be honest.
NitroDann wrote:I dont really understand what you just posted, to be honest.
in short,
if its a problem even on the new bpz3/ve,
gonna get rid of that problem, and do a reroute
- NitroDann
Ideally you change the head gasket to an earlier one, however a VVT motors cooling is still improved with a reroute without doing this.
NitroDann wrote:Ideally you change the head gasket to an earlier one, however a VVT motors cooling is still improved with a reroute without doing this.
gotta get an oversize head gasket, 85.5mm, dont think a stock gasket would fit
- NitroDann
Purchase an na8 headgasket, in that case. the na8 gasket and a reroute is the ultimate easy solution, and is pretty much ideal.
Yeah, I just checked a couple of NA8 gaskets that I've got: 84.4.Zabinskii wrote:gotta get an oversize head gasket, 85.5mm, dont think a stock gasket would fit
manga_blue wrote:Yeah, I just checked a couple of NA8 gaskets that I've got: 84.4.Zabinskii wrote:gotta get an oversize head gasket, 85.5mm, dont think a stock gasket would fit
yeah motor has been built with oversized pistons,
NitroDann wrote:Purchase an na8 headgasket, in that case. the na8 gasket and a reroute is the ultimate easy solution, and is pretty much ideal.
why na8 head gasket? whats the difference?
- NitroDann
http://www.miataturbo.net/race-prep-75/ ... ead-79930/
20 pages of in depth discussion to explain it.
The NA8 gasket that I'm using now came with every available port between the block and head fully open.
The one I had before that was maybe an NB one and there were 4 or 5 available ports blocked off. I ended up drilling them all out and opening them with a burr grinder before I fitted it. It's not easy to mod a gasket, they're hard as buggary and there's a risk of jamming removed metal in between the MLS layers but it is doable.
- zossy1
Paul, use a Cometic head gasket cut to 85.5mm. You can buy from Deckspeed or Fabre in Australia, or 949 racing or Trackspeed in the states. They use the NA8 / NB8A pattern. You will need to use a rerouted cooling system.
You can also use a Maruha head gasket, but they are very, very expensive.
zossy1 wrote:Paul, use a Cometic head gasket cut to 85.5mm. You can buy from Deckspeed or Fabre in Australia, or 949 racing or Trackspeed in the states. They use the NA8 / NB8A pattern. You will need to use a rerouted cooling system.
i found a cometic one on 949 and its 102$ says suitable for 85.5mm but im not sure if it comes at 85.5 or if it can be cut to 85.5mm
