High Speed Whistle noise
- Learner Driver
I have an NB SP and at speeds over 110kmh I get a high pitched whistle noise which changes with wind shear i.e. it is not constant. It sounds like something vibrating at high speed like a gum leaf whistle (if you remembers those) I have tried to locate it but really haven't clue as nothing seems to be loose. Any suggestions?
- Vehicle: ND - RF
Re: High Speed Whistle noise
Earplugs?
- Garry
My car used to do this and I traced it down to the rubber windscreen surround. To test put some tape around the windscreen to seal the rubber to the body. Mine was coming from the passenger side.
I got the windscreen replaced under warranty and it didn't do it after that.
- Learner Driver
Garry wrote:My car used to do this and I traced it down to the rubber windscreen surround. To test put some tape around the windscreen to seal the rubber to the body. Mine was coming from the passenger side.
Thanks Gary I will give it a try, I know Gerard had this windscreen replaced but not sure how many years ago so warranty may be a challenge. Regards
Geordie
White SP
Check the rubber seals around the side windows, mine was doing that after I changed my roof to mohair- New seals on the side fixed it.
- Learner Driver
22Silver wrote:Check the rubber seals around the side windows, mine was doing that after I changed my roof to mohair- New seals on the side fixed it.
Thanks I narrowed it down to the centre of the windscreen and a tiny bit of silicon stopped it.
