newbie looking for help with an na6
- Learner Driver
Hi all,
Sorry to come in looking for help of the bat.
I recently did the head on my wife's pride and joy which she has had for 15 years and everything thing seemed to go well but on trying to start the car it runs (bairly) chugs and won't rev at all
I thinks I've gone through every post looking for a solution and covered all possible options but the no avail.
Any help would be greatly appreciated
- NitroDann
Re: newbie looking for help with an na6
What have you tried?
- Learner Driver
So far checked and rechecked timing, spark, had injectors checked, new fuel pump and the afm appears to be working.
Not sure where to go from there
- Learner Driver
Also went over electrical connections checked cam sprockets and vacuum lines everything appears to be connected correctly, im at a loss
also put in your location.someone close by may be able to help.cam timing?
Mick
Mick
- Learner Driver
Thanks NooBee done
- bruce
- Vehicle: NA8 - Turbo
- Learner Driver
Not.the.leads checked.the.plugs for.spark with the.leads
Just wondering, is it possible to put the CAS in 180 degrees out or will it work either way?
- bruce
Spark plug leads.
Spark may not b strong enough or inconsistent.
Have another look at the cam timing, a lot of people manage to muck it up.
- Learner Driver
Ive checked and rechecked cam and belt timing all eceactly how it shoukd be
cas can only go on way
- Learner Driver
Over the weekend ill pist a video on the car chugging along, it wouldnt run at all if the cams were wrong would it
also rained the tank used new fuel replaced the pump blown out the fuel lines
Did you fill the HLAs with oil before you re-installed them? If you did then they're probably overfilled and as a result some of the valves aren't closing. Sitting under pressure in the engine lets the HLAs slowly bleed out the oil and return to normal working length. Leave it overnight and try again tomorrow.
have you checked the compression. . Are the valve clearances correct. Ps just noticed mangas post and he will recall that a member had a prob on a rebuilt head because the valves were not seating and the guy had to reset the clearances after buying new shims- it's a thought.
